Evening ping issue with FFXIV.
Icantcrabhere
Superfast
Hi there,
Getting some odd ping elevations the last few evenings on FFXIV (maybe a little before, which seemed more of a routing issue on one evening)
All hub stats are fine, as is my BQM,
which I'll post below after some screenshots.
First are some pings and traceroutes to neolobby06.ffxiv.com
Firstly normal ones during the day,
the other set is labeled as "After 7:52PM" which is when the elvations began today .
Noticed it slighty later in evening yesterday, after 8PM ish.
Next posts will be my router logs + BQM.
5 REPLIES 5
Icantcrabhere
Superfast
1723000000-0.237256 qam40
25390000000.738256 qam17
35470000000.438256 qam18
45550000000.238256 qam19
5563000000038256 qam20
6571000000-0.238256 qam21
7579000000038256 qam22
85870000000.438256 qam23
95950000000.938256 qam24
106030000000.738256 qam25
116110000000.538256 qam26
12619000000-0.238256 qam27
13627000000-0.438256 qam28
14635000000-0.537256 qam29
15643000000038256 qam30
166510000000.538256 qam31
17659000000138256 qam32
186670000000.938256 qam33
196750000000.538256 qam34
20683000000038256 qam35
21691000000038256 qam36
22699000000-0.237256 qam37
23707000000038256 qam38
24715000000037256 qam39
1Locked37.6730
2Locked38.6340
3Locked38.6420
4Locked38.9240
5Locked38.6280
6Locked38.9630
7Locked38.9460
8Locked38.6260
9Locked38.9200
10Locked38.9160
11Locked38.6540
12Locked38.6610
13Locked38.6820
14Locked37.6890
15Locked38.6670
16Locked38.6560
17Locked38.6460
18Locked38.9470
19Locked38.6460
20Locked38.6740
21Locked38.6730
22Locked37.6620
23Locked38.6740
24Locked37.6510
14960026345.8512064 qam1
22360000044.5512064 qam5
33010000044.8512064 qam4
44310001545.3512064 qam2
53660000045512064 qam3
1ATDMA0010
3ATDMA0000
4ATDMA0000
5ATDMA0010
Nothing of note in any other section.
Here is my BQM(Live):
https://www.thinkbroadband.com/broadband/monitoring/quality/share/1700d27c199ce3ea214d66ce063ff9f395...
Nothing out of the ordinary.
Had a friend check on his BT Connection, sitting at around 30 ping as normal.
Trying to get some friends with VM to check too. - but no luck yet!
Other games seem fine, League of Legends is at 22 ping, etc etc.
Not a VM problem from what I can tell
A friend who also play and use VM shared their results, they live in Stoke - so a good few hours away from me.chia results.png
Looks like it's hitting us both / others.
is their traceroute the same as yours as in IP hops?
Can you rephrase that if possible, Legacy?
I'm actually not understanding what you're trying to say.
Mine is taking 14 hops, theirs is 16.
I think I'm lacking coffee!
