WanderingJ
Message 1 of 5
Ethernet slower than wireless
Hub 3 wireless 190-200mbs , direct into Hun cat 6 cable 70-90mbs
anyone any ideas I have tried different cables , different ports
tried my desktop pc and a laptop
confused . Com
jb66
  • 12.43K
  • 925
  • 1.83K
Message 2 of 5
Re: Ethernet slower than wireless
Is your desktop and laptop have a 1Gig network card? If they only have 100 you won't get faster than 90
WanderingJ
Message 3 of 5
Laptop maybe but my desktop PC has intel I211 gigabit network connection on a gigabyte elite x570 motherboard
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 4 of 5
On the laptop ...
What speeds do you get at >>  SamKnows << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Then immediately after …
Can you Login to the Hub Settings and navigate to the Connected Devices page - what is the reported 'connection speed’ for the ethernet cable connected device you used for the speed test ?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 5 of 5
On the PC ...
