Ultra736
Message 1 of 8
Ethernet capped at 100mbps
Hello, I've recently connected an ethernet cable to my PC and have been hitting 300+ mbps. However, a couple days ago I've been experiencing new issues where the speed was capped at 100mbps, and wouldn't go up, no matter what I did. I've watched videos, read threads, posted on reddit and have done all the typical fixes that I've been told to do with no success! Now I've found out about the Virgin Media community and now need help as this issue could be something related to the router! Thank you in advance!
DJ_Shadow1966
  • 7.1K
  • 1.36K
  • 2.01K
Message 2 of 8
Re: Ethernet capped at 100mbps
Hello
Well without knowing what has been done, it is going to be near impossible to advise on what the next steps are so sorry if I am repeating what you have done.
Have you changed the Ethernet cable with a known good cable of Cat 5e or greater it will be marked on the cable ?
Is the Network Card running at 1.0 Gbps ?
How are you testing the speeds, I would say the best test is wired direct to the hub with a Cat 5e cable as that rules out any other equipment ?
www.speedtest.net is the best site.
Can you please post your network stats from the hub
Open a Web browser (e.g. Internet Explorer) and enter the address http://192.168.0.1
Note: If you have enabled Modem Mode on your Hub 3.0 you will need to use 192.168.100.1 instead.
Posting the stats by copy and paste will remove all personal information so no breaches.
Do not login but click on where it says "Check Router Stats" and then copy and post from the following 4 tabs, Downstream, Upstream, Configuration and Network logs (if they are pasted then all personal information is * out) and we can check your power level, also while you about that can you please go around and check that all connectors to VM equipment are hand tight. Also while doing this please check for any damage to cable, or un-terminated connection without either coax or a terminator.
Also please run "Check service status" at the top right of this forum and call 0800 561 0061 to check for local issues.
Also one think you can do is too signup at https://www.thinkbroadband.com/broadband/monitoring/quality and setup a broadband quality monitor which will keep an eye on you connection by sending a small amount of data to the hub asking if it still on.
Regards Mike
Ultra736
Message 3 of 8
Yeah I've checked with different cables, and everything in my PC supports 1Gbps. I will copy paste the information you have asked for:
386750000
Locked
Ranged Upstream Channel (Hz)
60300000
Locked
Provisioning State
Online
13867500001.938256 qam28
22027500003.940256 qam9
32107500003.538256 qam10
42187500002.738256 qam11
52267500002.238256 qam12
62347500002.538256 qam13
72427500002.738256 qam14
82507500002.538256 qam15
92587500002.738256 qam16
102667500002.438256 qam17
112747500002.438256 qam18
12282750000240256 qam19
132907500001.938256 qam20
142987500001.238256 qam21
153067500001.538256 qam22
163147500001.738256 qam23
17322750000238256 qam24
18330750000238256 qam25
193707500001.538256 qam26
203787500001.940256 qam27
213947500001.740256 qam29
224027500001.740256 qam30
234107500001.938256 qam31
244187500001.540256 qam32
1Locked38.9210
2Locked40.352187
3Locked38.9220
4Locked38.9170
5Locked38.6510
6Locked38.9370
7Locked38.9200
8Locked38.9290
9Locked38.9460
10Locked38.9270
11Locked38.9170
12Locked40.3290
13Locked38.9180
14Locked38.6240
15Locked38.6630
16Locked38.9120
17Locked38.680
18Locked38.9160
19Locked38.9260
20Locked40.360
21Locked40.3240
22Locked40.3160
23Locked38.9180
24Locked40.3170
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
3254k;*******;kfoA,.iyewrkld
SFID11636
Max Traffic Rate402500089
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID11635
Max Traffic Rate38500089
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
Ultra736
Message 4 of 8
I also have a cat 6 ethernet cable
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 5 of 8
Can you Login to the Hub Settings and navigate to the Connected Devices page - what does it report the 'connection speed’ as for the cable connected device you used for the speed test ?
  • 23.85K
  • 2.53K
  • 4.33K
Message 6 of 8
Can you try it this way and see what you get.
As you expect >100Mbps then connect a 1GB enabled computer/laptop, with up to date drivers, via a known good and working Cat5e (or better) ethernet cable, directly to the Hub which you have put into “modem mode” (see VM website for “How To”). Test at speedtest.net (not the App!) to your nearest VM server - try on 2 different browsers.
If they are still low – boot the device into safe+networking mode and try again.
There are many posts on here where unknown/flaky software, old network card drivers, corrupted browsers or other connected devices are limiting speeds on tests.
Ultra736
Message 7 of 8
Yeh in the connected devices it says 100mbps
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 8 of 8
That is the maximum speed you will get due to hardware restrictions.
Either the ethernet cable isn't to spec or is a bit iffy or the device Network Interface Card is too old or at the wrong settings.
