Hunter12392
  • 5
Ethernet and 360 box query
When fitting ethernet cable to 360box does it disable WiFi.
DavidJWalker
  • 781
  • 53
  • 118
Well-informed
Re: Ethernet and 360 box query
yes it does disable wifi if you connected a ethernet cable if you disconnect it will bring back the wifi its the way not being double connected its not needed
My Broadband Ping - Virgin Media 350MB
Using Ultimate Volt bundle
Just another VM user trying to help out so my answers may be wrong. If you do like my answer please mark it as helpful; it may help others
