DaveMacc
Ethernet Port speed
Excellent wifi 200MBps down and 20 up
Ethernet ports on hub 3  are capped at 100 MBps, I'm getting approx 85 MBps over  powerline adaptors, this degrades with distance and circuit, and consequently much slower in my office, wifi not good, hence use of powerline. So not getting value of 200MBps via Ethernet connection.
The new HUB 4 for Gigabit have ports and the assumption is a higher speed would pass through the ethernet connections.
So how do we get hub 4 without signing up for 1Gig
Any comments
Tags (3)
  • 2.88K
  • 216
  • 610
Trouble shooter
Re: Ethernet Port speed
Ethernet ports on hub 3  are capped at 100 MBps, I'm getting approx 85 MBps over  powerline adaptors, this degrades with distance and circuit, and consequently much slower in my office, wifi not good, hence use of powerline. So not getting value of 200MBps via Ethernet connection.The new HUB 4 for Gigabit have ports and the assumption is a higher speed would pass through the ethernet connections.So how do we get hub 4 without signing up for 1Gig
Any comments
Hub 3 ports are fully 10/100/1000 compliant depending on what it connected.  If a 100 device is connected the port will auto negotiate 100, same with 1000. Powerline adapters are not good for speed and should be avoided, they are only for convenience, nothing else.  If you want full speed to your office, you will have to run ethernet cable to the room.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
The 100Mbs is more than likely the speed that the Power Line Adaptors are set to.
If not the Power Line Adaptors it could be the device Network Interface Card [NIC] speed.
Older devices had NICs set at 10/100, they then moved to 10/100/100 then to 100/1000 and some are now set at 1000/10000.
If you go into the device settings you will see the NIC settings.
VMCopperUser
  • 3.59K
  • 122
  • 443
Trouble shooter
What powerline adapters do you have?
They are likely your issue, or the ethernet linking it to the Hub3 is.  Even some of the "Gigabit" cheap ones have a difficult time pushing >100.
I do not work for VM, but I would. It is just a Job.
Most things I say I make up and sometimes it's useful, don't be mean if it's wrong.
I would also make websites for them, because the job never seems to require the website to work.
DaveMacc
Thanks for your comment, seems my mistake. I use small upstairs  room as an office.
Devolo mesh Power line  is approx 110MBps and wifi 98MBps.
The Hub 3 is on ground floor behind TV. Wifi is 220 MBps tested  on mobile and amazon firestick...excellent.
If I connect firestick via  ethernet it drops to 88MBps....yes its the amazon ethernet adaptor rated at 100MBps.
Learnt something new...thanks again
DaveMacc
