  • 5
steelman232
Message 1 of 29
Etherent speed slow
Great. Kids gone to bed. Speed checked download speed on four different sites, 3 off good good. 8Mb. Paying for 50Mb. Usually always get 25-30. Why at 23.20 does it go back to speeds seen 15years ago,
Yes rebooted the router. Even tried a new Cat 6 cable.
  • 3.03K
  • 157
  • 464
jpeg1
Wise owl
Message 2 of 29
Re: Etherent speed slow
Have you called Customer Services to check your connection?
  • 626
  • 38
  • 40
Message 3 of 29
Hi steelman232,
Sorry to hear of the issues you've been having here with your slow speeds. Can I ask if there has been any change since your post?
Thank you.
Ryan_N - Forum Team
  • 11
matt50
Message 4 of 29
I also have that problem paying for vivid 200 & only geting 45 at best on a wired connection,customer services say its because i need a cat 6 cable instead of cat 5e but its been ok for years ? and it will cause me hassle to change the cable.
  • 626
  • 38
  • 40
Message 5 of 29
Hi matt50,
Welcome to the forums.
Sorry to hear about this also! Doesn't sound great, especially on a wired connection. How many devices are connected to the router? Also how long have you had this issue for?
Thank you.
Ryan_N - Forum Team
  • 11
matt50
Message 6 of 29
Hi Thanks
2 wired direct plus the use of electric extension,not sure what its called then maybe 5 wireless devices
  • 626
  • 38
  • 40
Message 7 of 29
How many larger devices run off the router? Like consoles or gaming computers as such.
Have you disconnected all connections and then rebooted?
Cheers 🙂
Ryan_N - Forum Team
  • 11
matt50
Message 8 of 29
now 1 xbox and 2 pc,also a few mobiles,a printer
  • 626
  • 38
  • 40
Message 9 of 29
Can you disconnect all devices for me so that there isn't a single connection running from the router, then turn it off for around a minute and back on, and then can you run me a speed test and post the results?
Thank you.
Ryan_N - Forum Team
  • 11
matt50
Message 10 of 29
hi
45 & 11 have tried this and the hard reset with customer services they still say its the cable because its not cat 6 although its been fine for years
