Error codes and low Signal to Noise Ratio
For few days now we've noticed problems with our speed so I had a look at the network status. We have one download channel (11) with a lower SNR (26) than the rest (35-38) and a very high (in the 10's of millions) error count. The network log shows two warning (Lost MDD Timeout and RCS Partial Service) are the are being reported roughly every 5 mins and are in pairs.
I reset the router earlier today, but the low SNR is still there, the error count is still high and the warnings are still as frequent.
I performed a number wired speed test over a 9 min period. The max speed achieved was 45.5 MBs, we are signed up for 100MBs, and the lowest speed was 2.67 MBs. I have also noticed there is a correlation with the low speed timings and the warnings being reported.
I've included the Down and Upstream Bonded Chanel information and the Network Log from the router along with a photo of the speed test results. This data is all from after the router reset.
Any help with this issue will be much appreciated, but personally I think there's an error on the line and we'll need an engineer call out .
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
147000000
7.1
37
256 qam
2
2
139000000
7.6
37
256 qam
1
3
155000000
7.1
37
256 qam
3
4
163000000
7.3
37
256 qam
4
5
171000000
7
37
256 qam
5
6
179000000
7
37
256 qam
6
7
187000000
6.9
36
256 qam
7
8
195000000
7.1
37
256 qam
8
9
203000000
6.4
37
256 qam
9
10
211000000
5.9
37
256 qam
10
11
219000000
5.9
24
256 qam
11
12
227000000
5.9
35
256 qam
12
13
235000000
6
38
256 qam
13
14
243000000
5.3
37
256 qam
14
15
251000000
5.8
37
256 qam
15
16
259000000
6
37
256 qam
16
17
267000000
6.1
38
256 qam
17
18
275000000
6.5
38
256 qam
18
19
283000000
6.4
37
256 qam
19
20
291000000
6.3
38
256 qam
20
21
299000000
6.5
38
256 qam
21
22
307000000
6.5
38
256 qam
22
23
315000000
6
38
256 qam
23
24
323000000
6.4
38
256 qam
24
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
37.3
6
0
2
Locked
37.6
7
0
3
Locked
37.6
6
0
4
Locked
37.6
5
0
5
Locked
37.6
2
0
6
Locked
37.3
10
0
7
Locked
36.6
6
0
8
Locked
37.3
14
0
9
Locked
37.6
6
0
10
Locked
37.6
4
0
11
Locked
24.3
10941190
78296269
12
Locked
35.7
15
0
13
Locked
38.6
10
0
14
Locked
37.6
6
0
15
Locked
37.6
8
0
16
Locked
37.6
6
0
17
Locked
38.6
0
0
18
Locked
38.6
5
0
19
Locked
37.6
6
0
20
Locked
38.6
5
0
21
Locked
38.6
6
0
22
Locked
38.6
5
0
23
Locked
38.6
0
0
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
53700002
4.2
5120
64 qam
10
2
39400017
3.975
5120
64 qam
12
3
46200004
4.025
5120
64 qam
11
4
60300002
4.075
5120
64 qam
9
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
0
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
0
0
4
ATDMA
0
0
0
0
Time
Priority
Description
02/01/2020 10:26:56
Warning!
Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/01/2020 10:26:56
Warning!
RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/01/2020 10:27:7
Warning!
02/01/2020 10:27:11
Warning!
02/01/2020 10:27:19
Warning!
02/01/2020 10:27:21
Warning!
02/01/2020 10:27:43
Warning!
02/01/2020 10:28:1
Warning!
02/01/2020 10:28:20
Warning!
02/01/2020 10:28:22
Warning!
02/01/2020 10:29:7
Warning!
02/01/2020 10:29:9
Warning!
02/01/2020 10:34:31
Warning!
Speed Test Results
  • 4.65K
  • 853
  • 1.23K
Re: Error codes and low Signal to Noise Ratio
Hello
Yes there is a problem with channel 11 low signal at 24 should be over 34, I would check that all coaxial connections to all VM equipment are finger tight and also check for any damage to cables.
If the SNR isnt resolved by checking the connections then an engineer is going to be needed to resolve the issue, so either call in on 150 or wait for a VM staff member to pick up the post.
Regards Mike
Thanks Mike.
Connectors are tight, but I'll take a look at the cable.
Mark
  • 1.34K
  • 81
  • 257
Hi Mark,
Welcome to our forums and thank you for your very detailed post. I'm really sorry that you've been having trouble with your broadband speed, we can certainly look to get this sorted for you.
I can also see low downstream SNR from our end, so it's likely that you'll need an engineer to resolve the fault. I'll send you a private message now to clear account security and arrange a visit.
It would still be worth checking your cables and connections, if this fixes the problem there's no need to reply to my message.
Rachael
