gracefield
  • 10
Message 1 of 16
Erratic speed
Hi, our Virgin Media broadband normally operates at around 180-200 mb/s but lately, it has become very erratic, the speeds are always different. Sometimes it falls below 90mb/s. The variation is almost constant, it never seems to stay at a constant speed.
Upstairs, we are very far from the hub and connect using powerline connections through the sockets. Not ideal, but this has worked well until now. Speeds are much lower but they have been steady and quite workable until now.
The drop in speed isn't as noticeable downstairs because it is still fast, even if it drops by half and unless you are testing it, you don't really notice.
But I think that the lower speed upstairs means that the newly erratic performance from the hub is much more noticeable. Sometimes it takes an hour to download a 1gb file, you cannot have simultaneous downloads now and you can't really access the web when it is downloading. Using the web upstairs has become a real trial.
Can anyone help with any suggestions? I have restarted the hub several times, restarted computers, changed the powerline adapter out, nothing helps. As I say, we were all OK until a day or two ago but this is driving me nuts.
Thank-you
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 16
Re: Erratic speed
How are you connecting your device[s], Wi-Fi or ethernet cable ?
gracefield
  • 10
Message 3 of 16
Re: Erratic speed
Thanks for replying. My wife's office downstairs is connected via wireless, she has a couple of PCs and a printer.
Upstairs, I am connecting via Netgear Powerlink adaptors through the electrical sockets. We also have an elderly BT extender plugged in at the top of the stairs which provides a wireless option, but the distance from the hub is great and there are a lot of walls, so it is very slow, it does for mobile devices upstairs.
As I say, we are experiencing very erratic, rapid drops and gains in speed. It's not that noticeable downstairs because they are running at around 200mb/s, but upstairs, where the speed is already much reduced, it is very noticeable and nothing seems to cure it.
We are about to have a mesh installed, but I need to get the base speed issue sorted first.
Many thanks
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 4 of 16
Re: Erratic speed
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting the area. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Then
Can you please
gracefield
  • 10
Message 5 of 16
Re: Erratic speed
My BQM
gracefield
  • 10
Message 6 of 16
Re: Erratic speed
Hi Mike
Downstream 483000000 locked
Upstream 53700021 locked
Provisioning status online
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 7 of 16
Re: Erratic speed
@gracefield wrote:
My BQM
I can see dropped packets already ...
dropped
gracefield
  • 10
Message 8 of 16
Re: Erratic speed
OK, I know what you want re the other info, but I am not able to post at the moment, apparently I am post flooding, I will have that info with you in a bit...
gracefield
  • 10
Message 9 of 16
Re: Erratic speed
1483000000-0.938256 qam32
22030000001.240256 qam9
3211000000140256 qam10
4219000000140256 qam11
5227000000140256 qam12
6235000000140256 qam13
72430000000.740256 qam14
82510000000.740256 qam15
92590000000.240256 qam16
102670000000.240256 qam17
11275000000040256 qam18
12283000000040256 qam19
13291000000-0.238256 qam20
14299000000-0.238256 qam21
15307000000-0.440256 qam22
16315000000-0.440256 qam23
17323000000-0.438256 qam24
18427000000-0.738256 qam25
19435000000-0.738256 qam26
20443000000-0.938256 qam27
21451000000-0.938256 qam28
22459000000-0.738256 qam29
23467000000-0.938256 qam30
24475000000-0.738256 qam31
1Locked38.610940
2Locked40.3810
3Locked40.9662
4Locked40.31220
5Locked40.31150
6Locked40.31160
7Locked40.31310
8Locked40.31230
9Locked40.31340
10Locked40.31200
11Locked40.913011
12Locked40.91410
13Locked38.91918
14Locked38.92480
15Locked40.91890
16Locked40.32190
17Locked38.91970
18Locked38.98130
19Locked38.99210
20Locked38.69200
21Locked38.69850
22Locked38.611250
23Locked38.911430
24Locked38.910880
gracefield
  • 10
Message 10 of 16
Re: Erratic speed
Upstream bonded channelsChannel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID
15370002142.8512064 qam6
23940021742.8512064 qam8
34620008042.8512064 qam7
46030008443512064 qam5
Upstream bonded channelsChannel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
1ATDMA0030
2ATDMA0020
3ATDMA0030
4ATDMA0010
