Bumfluff
  • 14
Message 1 of 24
Erratic broadband speeds WiFi/lan
Hi all,
hopefully you helpful lot can point me in the right direction. I’m in area 26 and only just joined VM in the last month. I’m currently having erratic speeds on my broadband at the minute. I take it with all the other questions on here About low speeds it’s a problem throughout VM? I’m having speed issues with wired and WiFi Connections. When I carried out a diagnostics check through the Router it came up with a Wi-Fi problem. How do I know what the Wi-Fi problem is? Is there somewhere that explains the fault? How do I get all the info needed so the experts can look through it and maybe point me in the right direction. Many thanks
gary_dexter
  • 30.68K
  • 1.91K
  • 4.08K
Message 2 of 24
Re: Erratic broadband speeds WiFi/lan
What speeds do you get wired?
Bumfluff
  • 14
Message 3 of 24
Im getting my speed ref from my PS4 connection test and speedtest app. Don’t tell me I’m using the wrong method of speed testing?
test on wired connected PS4 1.3mb down 2.3mb up.
ive attached pic of speedtest app which shows some results.
im on the 100mb VM package
Bumfluff
  • 14
Message 4 of 24
This any help -
11390000002.938256 qam1
21470000002.738256 qam2
31550000002.938256 qam3
41630000002.938256 qam4
5171000000338256 qam5
61790000002.938256 qam6
7187000000338256 qam7
81950000002.738256 qam8
92030000002.738256 qam9
102110000002.438256 qam10
112190000002.238256 qam11
12227000000238256 qam12
132350000002.238256 qam13
142430000002.238256 qam14
152510000002.238256 qam15
162590000002.238256 qam16
17267000000238256 qam17
18275000000238256 qam18
19283000000238256 qam19
20291000000238256 qam20
21299000000238256 qam21
22307000000238256 qam22
233150000001.938256 qam23
243230000001.738256 qam24
1Locked38.640
2Locked38.670
3Locked38.6200
4Locked38.9190
5Locked38.6220
6Locked38.6180
7Locked38.6210
8Locked38.6200
9Locked38.640
10Locked38.650
11Locked38.690
12Locked38.660
13Locked38.940
14Locked38.950
15Locked38.950
16Locked38.960
17Locked38.650
18Locked38.670
19Locked38.680
20Locked38.660
21Locked38.6180
22Locked38.950
23Locked38.960
24Locked38.650
Bumfluff
  • 14
Message 5 of 24
Upstream bonded channelsChannel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID
1537000593.675512064 qam6
2602996683.675512064 qam5
3394000003.7512064 qam8
4461999173.7512064 qam7
Upstream bonded channelsChannel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
3ATDMA0000
4ATDMA0000
gary_dexter
  • 30.68K
  • 1.91K
  • 4.08K
Message 6 of 24
Testing by a console is the worst way to speed test.
You need to use a gigabit-enabled laptop/PC
Bumfluff
  • 14
Message 7 of 24
Ok no worries I’ll do a speed test on the pc. ill let you know what I get.
appreciate your quick reply’s
Bumfluff
  • 14
Message 8 of 24
Pc speed test using speed test . Net
WiFi - 10.22 down 0.31up
wired(powerline adaptor) - 8.52 down 8.91 up
hope this helps
thanks
Anonymous
Not applicable
Message 9 of 24
what do you get without the powerline. Connected with ethernet directly to the hub
Bumfluff
  • 14
Message 10 of 24
Hi and good morning,
connecting my pc directly to the hub 3 -
110 down 9 up
using the same speed test app on my phone connected to VM Glasgow server
10 down 8 up.
Does that point to a WiFi issue?
