dudload
  • 23
Message 1 of 9
E2 - connection issues
Over the last week, I've been struggling with the internet connection here. We did have bad packet loss and latency spikes early last year, but Virgin seemed to fix them.
However, recently our speeds have dropped to about 180MB from the usual solid 380MB ish download, but webpages are extremely slow to load and remote connections can't seem to hold up.
There's no packet loss, but our upload speeds are terrible, receiving about 0.1-1MB upload. Can someone have a look at the local area network?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Message 2 of 9
Re: E2 - connection issues
A bit more information is required, please post the following ...
Please do this before posting the Hub Data
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Message 3 of 9
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
Copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs onto here, if you get a yellow / straw box warning click the Post button again.
Use one post for each tab if you wish.
Please do not use screen shots.
dudload
  • 23
Message 4 of 9
Hi, apologies for taking so long, but here are my logs:
Downstream bonded channelsChannel Frequency (Hz) Power (dBmV) SNR (dB) Modulation Channel ID
12027500000.238256 qam9
2210750000038256 qam10
3218750000-0.238256 qam11
4226750000-0.438256 qam12
5234750000-0.238256 qam13
6242750000038256 qam14
7250750000038256 qam15
8258750000038256 qam16
9266750000038256 qam17
10274750000-0.238256 qam18
11282750000-0.238256 qam19
12290750000-0.538256 qam20
13298750000-0.238256 qam21
14306750000-0.238256 qam22
15314750000038256 qam23
163227500000.438256 qam24
173307500000.438256 qam25
18370750000038256 qam26
193787500000.238256 qam27
203867500000.438256 qam28
213947500000.538256 qam29
224027500000.438256 qam30
234107500000.238256 qam31
24418750000038256 qam32
1Locked38.928553931305281
2Locked38.926034051010656
3Locked38.926771211159581
4Locked38.629637411596922
5Locked38.629757791557679
6Locked38.92629622874142
7Locked38.92375458427953
8Locked38.62146691242527
9Locked38.92137437256191
10Locked38.62332415356858
11Locked38.92410917368988
12Locked38.62415053387276
13Locked38.92211023362660
14Locked38.61939301316365
15Locked38.61673036325893
16Locked38.61438444285098
17Locked38.61247535153813
18Locked38.91265833177135
19Locked38.91072702223829
20Locked38.9813403214577
21Locked38.9649669161837
22Locked38.658671981724
23Locked38.969896150464
24Locked38.980526851471
dudload
  • 23
Message 5 of 9
13260000045.5512016 qam7
22579972745.5512016 qam8
34620000045.8512064 qam5
43939998545.3512064 qam6
1ATDMA00110
2ATDMA00470
3ATDMA0010
4ATDMA0020
dudload
  • 23
Message 6 of 9
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt062-b.cm
SFID277762
Max Traffic Rate402500089
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID277761
Max Traffic Rate38500089
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
dudload
  • 23
Message 7 of 9
25/01/2021 08:31:47Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/01/2021 05:55:57criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/01/2021 05:17:57Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/01/2021 05:17:54criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/01/2021 05:16:8Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/01/2021 04:39:53criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/01/2021 02:21:51Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/01/2021 02:21:48Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/01/2021 02:21:19Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/01/2021 02:20:48criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/01/2021 02:19:18Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/01/2021 02:18:57criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/01/2021 02:15:30Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/01/2021 02:15:29criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/01/2021 02:15:27Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/01/2021 02:14:54criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/01/2021 02:13:0Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/01/2021 02:12:27criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/01/2021 02:11:23Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/01/2021 02:10:49criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
dudload
  • 23
Message 8 of 9
heres my live BQM - shows packet loss spikes are bad today.
This is strange as had these issues about a year and a half ago (engineers kept blaming interference in my house), but were resolved, until now...
dudload
  • 23
Message 9 of 9
bump - anyone able to take a look? BQM shows huge (100% packet loss spikes still occurring regularly throughout the day)
