Insona
  • 21
Message 1 of 20
Dropped Packets and High Latency
Been having an issue I mostly see when Streaming to Twitch. I see frames dropped making it impossible to make content. I've had a Think Broadband trace on my internet and since mid November I have seen large Packet loss and quite often High Latency.
This is a major impact for me as its my work and  I rely on the income and the issues are now having a major impact on my mental health
When I've run speed tests on system I'm lucky to see over 10Mbps I actually did a test last night and it was at 1.29 Mbps when my average should be 35Mbps
I did manage to stream Monday night with no issues and after checking Think Broadband and there was no Packet loss
I've changed cables etc at a cost to myself to ensure no issues there but still the same
Please Help
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 2 of 20
Re: Dropped Packets and High Latency
Which Hub do you have ?
What is your contracted speed ?
What speeds do you get at >>  SamKnows << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Which cables did you replace ?
Insona
  • 21
Message 3 of 20
I have a Hub3 in modum mode with a ASUS GT-AX11000 ROG Rapture 802.11ax Tri-Band Gaming Router, Speed Up to 1.1 Gbps, MU-MIMO With OFDMA Tech, 3 Level Game Boost, Gamers Private Network, Game Radar for Server Connection as a Router
My Contracted Speed is 350Mbps Down 35Mbps Up
Cables change with connecting cables all to CAT6
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 4 of 20
Insona
  • 21
Message 5 of 20
Out at other job.
The speeds are intermittent they can hit 400 down 35 down at times depending on graph.
So was wondering how one snap shot test like this will help seems it fluctuates so much
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 6 of 20
It puts a picture to the problem.
If you don't want to do it please say so and I will not bother putting any more time into your problem.
Insona
  • 21
Message 7 of 20
for an example here are some other snapshots
Insona
  • 21
Message 8 of 20
I'm just trying to understand how that helps if there is a fluctuation in the reading thats why I'm here for to get help and to understand the issue.
Lets say I get another reading of 1.3 Mbps or 10Mbps or even 35Mbps trying to understand
Insona
  • 21
Message 9 of 20
Hi Here are the tests you requested
They are better at the moment on the Upload Speed but I'm not seeing the Packet Loss since about 1am this morning either. This has got better since the Christmas period finished. I've had no notification of possible issues in area etc But looking online there seems to be a lot of reports of Outages in my area. Newport , South Wales
Thank for you help and time
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 10 of 20
