mkmig
  • 19
Message 1 of 27
Dropouts, stutter, ping
I've got 300mb connection, and when I test it it always show good speed and upload. However the internet itself stutters and drops out frequently, just for a few seconds at time.
Even the TV which is in the same room as the router stutters at times on Netflix - while the speed test shows over 300mb.
I've done the test etc. Is there anything else I can do to sort it? Or is it just broadband overload because everyone else is at home?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 2 of 27
Re: Dropouts, stutter, ping
mkmig
  • 19
Message 3 of 27
My BQM
mkmig
  • 19
Message 4 of 27
Can you read something from the BQM? How does it look?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 5 of 27
It is showing that the local area is busy in the evening but not to a great extent.
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
Copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs onto here, if you get a yellow / straw box warning click the Post button again.
Use one post for each tab if you wish.
mkmig
  • 19
Message 6 of 27
Downstream
13230000007.540256 qam24
21390000006.440256 qam1
31470000006.638256 qam2
41550000006.540256 qam3
51630000006.840256 qam4
61710000006.940256 qam5
7179000000740256 qam6
81870000007.340256 qam7
91950000007.340256 qam8
102030000007.140256 qam9
11211000000740256 qam10
122190000006.640256 qam11
132270000006.340256 qam12
142350000005.940256 qam13
152430000005.940256 qam14
16251000000638256 qam15
172590000006.538256 qam16
182670000006.840256 qam17
19275000000740256 qam18
202830000007.438256 qam19
212910000007.538256 qam20
222990000007.538256 qam21
23307000000738256 qam22
243150000007.140256 qam23
1Locked40.3220
2Locked40.32537000
3Locked38.93114780
4Locked40.33927190
5Locked40.32493440
6Locked40.3890740
7Locked40.920750
8Locked40.9210
9Locked40.380
10Locked40.9130
11Locked40.3140
12Locked40.3440
13Locked40.33020
14Locked40.3850
15Locked40.3830
16Locked38.9720
17Locked38.91330
18Locked40.39360
19Locked40.33950
20Locked38.91010
21Locked38.9420
22Locked38.9350
23Locked38.9390
24Locked40.3410
mkmig
  • 19
Message 7 of 27
Upstream
13939998543.5512064 qam4
25369996644.3512064 qam2
36030000044.5512064 qam1
44620000044512064 qam3
3ATDMA0020
4ATDMA0010
mkmig
  • 19
Message 8 of 27
Configuration
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt062+voc-b.cm
SFID464976
Max Traffic Rate402500089
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID464975
Max Traffic Rate38500089
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
mkmig
  • 19
Message 9 of 27
10/01/2021 12:05:7noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/01/2021 12:04:56Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/01/2021 06:27:24criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/01/2021 19:46:28ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/01/2021 10:35:3criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/01/2021 00:03:47noticeSW download Successful - Via NMS
06/01/2021 00:01:39noticeSW Download INIT - Via NMS
04/01/2021 22:55:53criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/01/2021 20:43:28ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/01/2021 13:09:16Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:37criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/2021 02:26:46ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/12/2020 18:42:15criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/12/2020 18:19:5Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/12/2020 10:09:4criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/12/2020 09:56:30Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/12/2020 15:19:41ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:34criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/12/2020 09:10:31criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/12/2020 09:09:7criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
mkmig
  • 19
Message 10 of 27
Were you able to read something from it?
