Matthewwallace
  • 12
Message 1 of 8
Dropouts at peak times
Can someone have a look at my BQM last night whilst streaming and gaming i was getting a lot of freezing and dropouts. When using a vpn this stopped. As soon as i would disconnect vpn freezing would restart.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 8
Re: Dropouts at peak times
Can you post a 'Live Link' to your BQM please.
Matthewwallace
  • 12
Message 3 of 8
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 4 of 8
Your >> BQM << looks good.
Let us know when you have done more gaming and had problems and we can look again.
In the meantime can you please
When the page appears DO NOT LOG IN but click ‘Check Router Status’.
Copy and paste the contents of the Downstream, Upstream and Network Log tabs onto here, if you get a yellow warning click the Post button again.
Matthewwallace
  • 12
Message 5 of 8
The issue happened last night around 9pm . Could this be throttling? Very weird how the vpn avoided the issue as soon as turned on
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 6 of 8
They don't throttle.
Can you carry out a couple of speed tests at speedtest.net using a direct connection using a Cat 5E/6 cable between the Hub and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected.
Ensure that the Network Interface Card (NIC) drivers are up to date.
Then post the links to the results on here.
Then do the same using your VPN.
Matthewwallace
  • 12
Message 7 of 8
The vpn speed is a lot slower than the speedtest without. But with vpn on streaming and gaming work fine. Without vpn on it freezes every second  as if the connection is dropping constantly this only happens at peak times
Matthewwallace
  • 12
Message 8 of 8
Can anyone explain this?
