miro_the_cat
  • 10
Message 1 of 13
Drop outs and slowdown
Hi, over the last few weeks I've been experiencing increasing drops out. Speeds between 5mbps and 200mbps but completely unpredictable. Video calls fail regularly. I can literally see it on my phone - the WiFi goes - and then all devices stop .
Have reset the hub using to 10second, and 1 minute resets over the past few weeks. Finally got through to technical and they sent a signal to my box as said it needed it. Hasn't improved, maybe even got worse. No time of day is better or worse. Affects all my devices.
Started off confused. Then got frustrated. Now I'm just angry. Pay good money for the worst internet I've had since my first dial up
Cable Modem Status
Item
Status
Comments
139000000
Locked
Ranged Upstream Channel (Hz)
39400000
Locked
Provisioning State
Online
miro_the_cat
  • 10
Message 2 of 13
Re: Drop outs and slowdown
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
139000000
6.6
38
256 qam
1
2
147000000
6
38
256 qam
2
3
155000000
6
38
256 qam
3
4
163000000
5.9
40
256 qam
4
5
171000000
5.6
40
256 qam
5
6
179000000
5.5
40
256 qam
6
7
187000000
5
38
256 qam
7
8
195000000
3.5
38
256 qam
8
9
203000000
4
38
256 qam
9
10
211000000
4.8
38
256 qam
10
11
219000000
4.9
40
256 qam
11
12
227000000
5
40
256 qam
12
13
235000000
4.6
38
256 qam
13
14
243000000
3
38
256 qam
14
15
251000000
3.7
38
256 qam
15
16
259000000
4.9
40
256 qam
16
17
267000000
4.8
38
256 qam
17
18
275000000
5
38
256 qam
18
19
283000000
5
38
256 qam
19
20
291000000
4.9
38
256 qam
20
21
299000000
5.1
38
256 qam
21
22
307000000
4.6
38
256 qam
22
23
315000000
5
40
256 qam
23
24
323000000
4.4
38
256 qam
24
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
38.9
8073
5702
2
Locked
38.9
5469
1012
3
Locked
38.9
175
0
4
Locked
40.3
2404
1
5
Locked
40.9
396
0
6
Locked
40.3
117
0
7
Locked
38.9
1357
0
8
Locked
38.9
5070
1227
9
Locked
38.6
4461
533
10
Locked
38.9
139
0
11
Locked
40.9
150
0
12
Locked
40.3
4150
88
13
Locked
38.9
3812
90
14
Locked
38.6
308
0
15
Locked
38.9
139
0
16
Locked
40.9
50
0
17
Locked
38.9
155
0
18
Locked
38.9
675
0
19
Locked
38.9
179
0
20
Locked
38.9
27
0
21
Locked
38.9
39
0
22
Locked
38.9
65
0
23
Locked
40.3
49
0
24
Locked
38.9
408
0
miro_the_cat
  • 10
Message 3 of 13
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
39400000
4.475
5120
64 qam
2
2
46200000
4.525
5120
64 qam
1
3
32600000
4.35
5120
64 qam
3
4
25800000
4.3
5120
64 qam
4
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
0
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
0
0
4
ATDMA
0
0
0
0
Time
Priority
Description
25/07/2020 12:10:2
notice
LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:31
critical
23/07/2020 14:30:54
Warning!
RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/07/2020 21:14:18
critical
22/07/2020 02:39:40
Warning!
22/07/2020 01:57:30
critical
22/07/2020 01:55:6
Warning!
21/07/2020 15:16:29
notice
21/07/2020 07:53:53
Warning!
21/07/2020 01:34:32
critical
20/07/2020 12:00:51
Error
DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/07/2020 12:11:3
critical
16/07/2020 08:31:15
Warning!
16/07/2020 04:58:21
critical
16/07/2020 00:34:42
Warning!
15/07/2020 23:49:39
critical
15/07/2020 22:33:22
Warning!
01/01/1970 00:02:14
critical
15/07/2020 15:47:50
Error
DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/07/2020 15:46:21
Error
Anonymous
Not applicable
Message 4 of 13
Do you experience the same issue on wired and wireless devices?
miro_the_cat
  • 10
Message 5 of 13
Wired is definitely more stable I would say, though still has drops outs - eg sonos is wired, but has drops outs. But perhaps not quite as frequently?
Anonymous
Not applicable
Message 6 of 13
Looking at the stats there are a number of 'Pre RS' and 'Post RS' Errors on your downstream channels, which normally means noise on the line.
When was the last time your HUB was rebooted?
A VM staff member should see this thread and investigate further.
miro_the_cat
  • 10
Message 7 of 13
Hi, depends what you mean by a reboot. I did a hard reset about 10 days ago using a method shown me by a technician using the reset button for 60 seconds. It has had a signal sent via technical support. And several 10 second resets over the last few weeks.
Anonymous
Not applicable
Message 8 of 13
Yes a hard reset would also set the error count back to zero.
If these errors build up quickly over a short period of time it does point to what I suggested above.
miro_the_cat
  • 10
Message 9 of 13
Many thanks!
I'll wait for a VM staff member...
Emily_G
  • 4.82K
  • 209
  • 286
Message 10 of 13
Thanks for the post Miro_the_cat, if you're still experiencing the errors following a pin hole reset I'll pop you over a private message so we can pass security and book an engineer appointment.
Thanks, Emily.
