Dreadfully slow upload speed in BH17 area
JeremySaul
Dialled in
For several days our broadband has been virtually unusable. We have M250 and our downlink speed remains at around 250Mbps. However uplink speed reported by Ookla Speedtest is never more than 1Mbps and is frequently as low os 0.2Mbps. As a result any webpage that involves interaction (online shopping, OneDrive file sync, even posting this message) is almost impossible to use. We have resorted to HotSpotting our laptop of one of our mobile phones to do somethings. Rebootring the modem makes no difference.
I have been given a fault ref of F011109320 but no clear indication of what the problem is, where it lies or when it will be fixed. First date was last Friday, now it will be Monday. When I spoke to VM I was told there have been lots of reports of the problem.
Looking at my router I see that all uplink channels are running on QAM16 instead of QAM64 which is presumably a consequence of the problem. Does any one have any information about this problem or when it might be fixed?
27 REPLIES 27
So now it is suggested it will be 21st December before a fix. How can you pretend that you are working hard on fixing it? Please let's have some honesty. What is the problem - in full technical detail. Where is the problem. What is the reason for the delay in fixing it.
Enough of your platitudes. Let's have some truth, please.
Reemul
Looks like it is fixed, good new for xmas at least
rfonline
yeah it's fixed great speeds
rfonline
 DOWNLOAD Mbps
950.61
 UPLOAD Mbps
105.28
Can't wait to get home and try it!
Kain_W
Hi JeremySaul,
Thanks again for your updates on this matter.
Has the matter been resolved for you?
Do keep us posted.
Regards,
Kain
JeremySaul
Dialled in
Yes it has, thank you. Shame it took so long...
Kain_W
Thanks for confirming this!
We're glad the matter has been resolved however many apologies for the delays in getting this fixed.
Do pop back up if you require any further assistance.
Take care,
Kain
