For some time my broadband speed has been maxing out at 9.5Mbps, tested throughout the day and night, using both wired and wireless devices (I am on a 100Mbps plan). Upload speed is as expected, varying between 6 and 9.5Mbps. I have performed several hard resets of the router and I have checked the cable connections for tightness but nothing seems to change the maximum downstream speed results.
When I check my modem status sheet Downstream Power Levels appear to be too high, averaging around +13dBmV per channel. I understand the correct range should be between -3 and +8dBmV. Upstream Power looks ok at +40dBmV (I understand this should be between +31 and +54).
Signal-to-noise ratio looks fine (around 37db per channel), but I am getting a significant number of Post RS Errors logged in the router's diagnostic sheets.
Unless anyone on this forum has a simple solution, I would be extremely grateful if a VM engineer could look into this as soon as possible. Attempts to discuss the issue with VM customer services and to raise formal complaints have been fruitless to date.
The slow speeds are having a real practical impact on every member of my family's practical lives as we try to work from home and school from home at the same time (all online with frequent video streams!). I would be satisfied to get the minimum service speed VM promises on my plan, which I think is 54Mbps. Anything over that number would be a welcome bonus, but I'm not sure why I'm paying for a service that is not even 20% as fast as the "slowest" download speed I'm meant to get.
Thanks - any help anyone can offer would be very much appreciated!
