on 30-05-2023 23:13
Anyone notice any issues with this?
I’m on Gig1 Broadband and recently, it seems sluggish.
TV has also been pixelating every now and then but has happened more today.
Any advice and support is appreciated
1 | 331000000 | 5.6 | 42 | QAM 256 | 25 |
2 | 179000000 | 4.7 | 41 | QAM 256 | 6 |
3 | 187000000 | 5.1 | 41 | QAM 256 | 7 |
4 | 195000000 | 5.3 | 41 | QAM 256 | 8 |
5 | 203000000 | 5.1 | 41 | QAM 256 | 9 |
6 | 211000000 | 5.3 | 42 | QAM 256 | 10 |
7 | 219000000 | 5.4 | 42 | QAM 256 | 11 |
8 | 227000000 | 5.5 | 42 | QAM 256 | 12 |
9 | 235000000 | 5.3 | 42 | QAM 256 | 13 |
10 | 243000000 | 5 | 42 | QAM 256 | 14 |
11 | 251000000 | 4.8 | 41 | QAM 256 | 15 |
12 | 259000000 | 5 | 42 | QAM 256 | 16 |
13 | 267000000 | 4.9 | 42 | QAM 256 | 17 |
14 | 275000000 | 4.6 | 41 | QAM 256 | 18 |
15 | 283000000 | 4.5 | 42 | QAM 256 | 19 |
16 | 291000000 | 4.7 | 42 | QAM 256 | 20 |
17 | 299000000 | 4.6 | 42 | QAM 256 | 21 |
18 | 307000000 | 4.4 | 41 | QAM 256 | 22 |
19 | 315000000 | 4.6 | 42 | QAM 256 | 23 |
20 | 323000000 | 5.2 | 42 | QAM 256 | 24 |
21 | 339000000 | 5.9 | 42 | QAM 256 | 26 |
22 | 347000000 | 5.9 | 42 | QAM 256 | 27 |
23 | 355000000 | 6 | 42 | QAM 256 | 28 |
24 | 363000000 | 6.3 | 42 | QAM 256 | 29 |
25 | 371000000 | 6.5 | 42 | QAM 256 | 30 |
26 | 379000000 | 6.6 | 42 | QAM 256 | 31 |
27 | 387000000 | 6.8 | 42 | QAM 256 | 32 |
28 | 395000000 | 6.8 | 42 | QAM 256 | 33 |
29 | 403000000 | 6.5 | 42 | QAM 256 | 34 |
30 | 411000000 | 6.1 | 42 | QAM 256 | 36 |
31 | 419000000 | 5.9 | 42 | QAM 256 | 37 |
1 | Locked | 42 | 6 | 0 |
2 | Locked | 41 | 23 | 0 |
3 | Locked | 41 | 6 | 0 |
4 | Locked | 41 | 8 | 0 |
5 | Locked | 41 | 10 | 0 |
6 | Locked | 42 | 8 | 0 |
7 | Locked | 42 | 11 | 0 |
8 | Locked | 42 | 9 | 0 |
9 | Locked | 42 | 8 | 0 |
10 | Locked | 42 | 9 | 0 |
11 | Locked | 41 | 8 | 0 |
12 | Locked | 42 | 8 | 0 |
13 | Locked | 42 | 8 | 0 |
14 | Locked | 41 | 6 | 0 |
15 | Locked | 42 | 5 | 0 |
16 | Locked | 42 | 7 | 0 |
17 | Locked | 42 | 6 | 0 |
18 | Locked | 41 | 13 | 0 |
19 | Locked | 42 | 10 | 0 |
20 | Locked | 42 | 10 | 0 |
21 | Locked | 42 | 5 | 0 |
22 | Locked | 42 | 3 | 0 |
23 | Locked | 42 | 6 | 0 |
24 | Locked | 42 | 3 | 0 |
25 | Locked | 42 | 10 | 0 |
26 | Locked | 42 | 6 | 0 |
27 | Locked | 42 | 6 | 0 |
28 | Locked | 42 | 8 | 0 |
29 | Locked | 42 | 5 | 0 |
30 | Locked | 42 | 4 | 0 |
31 | Locked | 42 | 6 | 0 |
on 01-06-2023 17:34
Stats look good so far. How about the upstream ones?
on 01-06-2023 18:00
0 | 49600000 | 47.3 | 5120 | QAM 64 | 1 |
1 | 43100000 | 47.3 | 5120 | QAM 64 | 2 |
2 | 36600000 | 47 | 5120 | QAM 64 | 3 |
3 | 30100000 | 47 | 5120 | QAM 64 | 4 |
4 | 23600000 | 46.8 | 5120 | QAM 64 | 5 |
0 | ATDMA | 0 | 0 | 0 | 0 |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 1 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
on 01-06-2023 18:48
Yeah they are okay too.
I would really expect the presence of a Docsis 3.1 upstream and downstream channel here. Others may wish to advise on this.
on 01-06-2023 19:21
@Cardiffman282 wrote:Yeah they are okay too.
If they have a hub5 you are not allowed to see those.
Also, I bet it's noise on the 3.1 channels causing problems.
01-06-2023 19:24 - edited 01-06-2023 19:25
@cardiffman282 Thanks for taking a look
on 01-06-2023 19:27
Thanks for the heads up.
Virgjn, can you check this for me please
on 04-06-2023 11:31
Hi james-28,
Thank you for reaching out to us in our community and welcome back, I was able to locate you on our system with the details we have for you and cannot see any issues, after running checks it is advised that you check all your internal connections coming into the property are hand tight, this includes all equipment plus any splitters both powered and standard, once done unplug the Router from the power for 2 to 3 minutes then plug in again.
Paul.
04-06-2023 14:42 - edited 04-06-2023 14:43
Hi Paul,
Thanks for checking and thanks for the reply. Since first posting I have factory reset the hub and pods with no change in performance.
However, i temporarily changed the SSID and then reverted back to the original SSID and now everything is fine, no issues with performance and speeds are spot on.
Doing this also fixed the issues I was having with the connect app and is working as normal 👍🏼
on 06-06-2023 14:45
Hey @james-28,
Great to hear everything is back and working, do let us know if you require anything further or if you have any other questions, we would be happy to help.
Cheers. Joe
