alexanderb81
  • 20
Message 1 of 12
Downstream Power Levels - Are they OK?
Hi All
Trying to familiarise myself with my Volt Gig1 connection that has been applied to my account this week, with a Hub 4. I have tried to follow a few suggestions on these forums, and came across a very useful post about understanding Hub Status info. It looks to be pinned, and I am not sure if I can post the link without breaking any rules.
Further down in the comments, it was mentioned that acceptable downstream power levels "should be within the range of -6 to +10" Are my levels below acceptable, or should I try request an engineer visit, as a number of channels are out of the +10 range, or is this still considered acceptable?
3.0 Downstream channels
253310000009.40000240.946209QAM25625
113900000012.09999840.946209QAM2561
214700000011.69999740.946209QAM2562
315500000011.69999740.366287QAM2563
416300000011.50000040.366287QAM2564
517100000011.19999740.366287QAM2565
617900000011.19999740.946209QAM2566
718700000011.19999740.366287QAM2567
819500000011.30000340.946209QAM2568
920300000011.19999740.366287QAM2569
1021100000011.19999740.946209QAM25610
1121900000011.19999740.946209QAM25611
1222700000011.19999740.946209QAM25612
1323500000011.30000340.366287QAM25613
1424300000011.40000240.946209QAM25614
1525100000011.19999740.946209QAM25615
1625900000011.40000240.946209QAM25616
1726700000011.40000240.366287QAM25617
1827500000011.09999840.366287QAM25618
1928300000010.90000240.366287QAM25619
2029100000010.69999740.366287QAM25620
2129900000011.00000040.366287QAM25621
2230700000010.90000240.366287QAM25622
2331500000010.59999840.366287QAM25623
2432300000010.19999740.946209QAM25624
263390000009.40000240.366287QAM25626
273470000009.30000340.366287QAM25627
283550000009.19999740.366287QAM25628
293630000009.00000040.366287QAM25629
303710000009.00000040.366287QAM25630
313790000009.00000040.946209QAM25631
alexanderb81
  • 20
Message 2 of 12
Re: Downstream Power Levels - Are they OK?
25Locked40.94620900
1Locked40.94620900
2Locked40.94620900
3Locked40.36628700
4Locked40.36628700
5Locked40.36628700
6Locked40.94620900
7Locked40.36628700
8Locked40.94620900
9Locked40.36628700
10Locked40.94620900
11Locked40.94620900
12Locked40.94620900
13Locked40.36628700
14Locked40.94620900
15Locked40.94620900
16Locked40.94620900
17Locked40.36628700
18Locked40.36628700
19Locked40.36628700
20Locked40.36628700
21Locked40.36628700
22Locked40.36628700
23Locked40.36628700
24Locked40.94620900
26Locked40.36628700
27Locked40.36628700
28Locked40.36628700
29Locked40.36628700
30Locked40.36628700
31Locked40.94620900
3.1 Downstream channels
33964K1880QAM4096759
33Locked436.0290463060
  • 6.8K
  • 591
  • 1.78K
Message 3 of 12
Your power levels are indeed too high.  The range you quoted is correct and they need reduced closer to the mid point.
How are the Upstream power levels?  They should be between 34 and 51.
If you wait here a day or two a VM Mod will pick this up and hopefully arrange a technician to sort it out.
alexanderb81
  • 20
Message 4 of 12
Thanks Adduxi
I believe upstream levels are OK, but posting them for refernece:
3.0 Upstream channels
15370000039.2705995120 KSym/sec64QAM7
24620000039.0205995120 KSym/sec64QAM8
33940000038.7705995120 KSym/sec64QAM9
46030000039.2705995120 KSym/sec64QAM6
1US_TYPE_STDMA0000
2US_TYPE_STDMA0000
3US_TYPE_STDMA0000
4US_TYPE_STDMA0000
-tony-
  • 19.2K
  • 1.46K
  • 3.76K
Message 5 of 12
upstream is fine - downstream as said is a bit too high - when you swapper the hub was there an attenuator on the old hub - if so have you put it on the new one - would have been the coax and the connector on the hub
if not the big question is do you have problems if not then you can argue it does not need fixing - if you do or if you do want the levels to be in spec then you need a tech - you can ring but that can have mixed results or wait here for VM they will book something
____________________
Tony.
Sacked VIP
alexanderb81
  • 20
Message 6 of 12
Hi Tony
there was no attenuator on the old hub. It was a Hub 3 with a brand new (m500) install in August 2020. I'm experiencing some performance loss, and tried various methods such as direct to hub in modem mode, in router mode checking samknows, different cable etc. The only thing I cant try at this point is a different cabled device as I don't have any available. So until I can find another device to bring into the network to test, I can't say for certain if its my device that's responsible, or if the Hub, and line are worth looking at?
My samknows was 1128 to the hub, but 399 to the device, but ookla speedtests have shown up to 535. Uploads are fine at around 52Mbps so I don't think there are issues there. If an admin thinks there could be some help in getting an engineer out and bring the levels in line, that will be great and one thing checked off.
Zach_R
  • 4.89K
  • 159
  • 336
Message 7 of 12
Hi @alexanderb81,
Thank you for your posts and welcome back to our community forums. We're here to help.
I am so sorry to hear that you appear to be having some problems with your connection following a package and router upgrade. I'm going to send you a private message in a moment so that we can take some details and have a closer look at what's going on. As has been discussed here, we may need to arrange a technician visit and we can do that there too.
Please respond to this at your earliest convenience and we can go from there.
Zach - Forum Team
Zach_R
  • 4.89K
  • 159
  • 336
Message 8 of 12
Hi @alexanderb81,
Thank you for reaching back out to me via private message so we could have a closer look at what's going on.
As discussed there, a technician visit has now been scheduled and booked. I'm unable to confirm the date or time of the booking publicly, but you can check and manage/reschedule it if needed via your My Virgin Media online account.
Let us know how the visit goes.
Zach - Forum Team
alexanderb81
  • 20
Message 9 of 12
Thank you very much for your assistance Zach
Kain_W
  • 3.72K
  • 102
  • 265
Message 10 of 12
Thanks for the responses alexanderb81,
Welcome back to the community!
If you do face further issues after the appointment then let us know and we'll run further checks.
Take care for now,
Kain
