quelopera58
Download speeds way higher than expecting, over 1/2gbps?
I pay for the new 500mb down when i speed test on i usally get around 600-900mbs down, but sometimes when i test i can get easily over 1gbs and a few times over 2gbs. The last time i done a speed test was Friday and i had 2.4gbs download, does anyone know why this is? I live in Bristol if location makes a difference.
SCA1972
  • 5.91K
  • 662
  • 2.02K
Re: Download speeds way higher than expecting, over 1/2gbps?
Sounds like a faulty speed test. None of the VM hubs are capable of delivering the top speed you describe to devices on your LAN as they are only fitted with Gigabit Ethernet ports which have a real world speed of around 900Mbps. The wireless capabilities are even slower.
I have seen reports of weird speed test results in the past, not sure if it is a test site issue or a browser issue.
______________________
Scott
My setup: VM TV box, M350 Fibre broadband with Hub 3 in modem mode connected to a Netgear R7000 router. Telewest/VM user since 2001.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
What speeds do you get at >> speedtest.net << with a direct connection using a Cat 5E or better cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Please link to the result onto here.
