Evilscotsman
Message 1 of 7
Download speed
Hi I have a hub 3 and M350 broadband. While trying to download a game I ran a test, with LAN connection, The test I ran came back with 44 mb/s download speed but actually downloading at 4 mb/s.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 2 of 7
Re: Download speed
How are you connecting your device[s], Wi-Fi or ethernet cable ?
Evilscotsman
Message 3 of 7
Re: Download speed
I'm always connected via ethernet. I saw a tip to disable the router firewall this did make a slight difference but still not the speed I should be getting.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 4 of 7
Re: Download speed
Go into the Hub Settings > Connected Devices and see what the connection speed for your device is.
Evilscotsman
Message 5 of 7
Re: Download speed
Its showing a connection speed of 1000 mb/s. We don't have 1gb where I stay
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 6 of 7
Re: Download speed
That tells you that the Local Area Network (LAN) is capable of 1000Mbs.
Do you have any third party equipment such as Power Line Adaptors [PLA] (doubtful) or Router between the PC and the Hub?
Evilscotsman
Message 7 of 7
Re: Download speed
Sorry it took so long to reply. Its my ps4 and its connected directly to the hub. Like I said when I disabled the firewall on the hub the download went from a 9 hour timer down to around 40 min, but i think it should've taken less than that.
