miaitken
  • 23
Download speed
I have been advised that my download speed has now been increased to 200mbps
Just done a test and it shows a reading of 48.9mbps
any suggestions please
Malcolm
DJ_Shadow1966
  • 7.11K
  • 1.36K
  • 2.01K
Re: Download speed
Hello
Thank for joining in on the forum, we will try the best to get your issue resolved.
How are you doing the speedtest is it either wired or wireless, wired direct to the hubis always the best option and this is what VM guarantee.
Can you please post your network stats from the hub
Open a Web browser (e.g. Internet Explorer) and enter the address http://192.168.0.1
Note: If you have enabled Modem Mode on your Hub 3.0 you will need to use 192.168.100.1 instead.
Posting the stats by copy and paste will remove all personal information so no breaches.
Do not login but click on where it says "Check Router Stats" and then copy and post from the following 4 tabs, Downstream, Upstream, Configuration and Network logs (if they are pasted then all personal information is * out) and we can check your power level, also while you about that can you please go around and check that all connectors to VM equipment are hand tight. Also while doing this please check for any damage to cable, or un-terminated connection without either coax or a terminator.
Also please run "Check service status" at the top right of this forum and call 0800 561 0061 to check for local issues.
Also one think you can do is too signup at https://www.thinkbroadband.com/broadband/monitoring/quality and setup a broadband quality monitor which will keep an eye on you connection by sending a small amount of data to the hub asking if it still on.
Regards Mike
