sjw444
Download speed
I was regularly getting around 600mb download speeds from my wired connected PC. However, my download speed tests are now topping out at around 300mb. It's not my PC as I have run speed tests with a second PC and my laptop all wired directly into my hub with a similar result
Looking at my router status stats I appear to have some issues. Can anybody help?
Cable Modem Status
Item Status Comments
Acquired Downstream Channel (Hz) 419000000 Locked
Ranged Upstream Channel (Hz) 53699871 Locked
Provisioning State Online
1 419000000 -0.2 40 256 qam 30
2 187000000 -2.2 40 256 qam 7
3 195000000 -2 40 256 qam 8
4 203000000 -2 40 256 qam 9
5 211000000 -2.2 40 256 qam 10
6 219000000 -2.2 40 256 qam 11
7 227000000 -2.5 40 256 qam 12
8 235000000 -2.7 40 256 qam 13
9 243000000 -2.7 40 256 qam 14
10 251000000 -2.7 40 256 qam 15
11 259000000 -2.2 40 256 qam 16
12 267000000 -1.7 40 256 qam 17
13 275000000 -1.7 40 256 qam 18
14 283000000 -1.7 40 256 qam 19
15 291000000 -1.5 40 256 qam 20
16 299000000 -1.7 40 256 qam 21
17 307000000 -1.9 40 256 qam 22
18 315000000 -1.7 40 256 qam 23
19 323000000 -1.5 40 256 qam 24
20 379000000 -1 40 256 qam 25
21 387000000 -1 40 256 qam 26
22 395000000 -1 40 256 qam 27
23 403000000 -1 40 256 qam 28
24 411000000 -0.5 40 256 qam 29
1 Locked 40.9 339 34
2 Locked 40.3 94276 663
3 Locked 40.9 1507 143
4 Locked 40.3 1586 212
5 Locked 40.3 1456 153
6 Locked 40.9 755 6140
7 Locked 40.9 1112 4581
8 Locked 40.9 913 77
9 Locked 40.3 991 108
10 Locked 40.3 1068 123
11 Locked 40.3 1000 148
12 Locked 40.9 796 113
13 Locked 40.9 598 59
14 Locked 40.3 597 39
15 Locked 40.3 525 50
16 Locked 40.3 513 111
17 Locked 40.9 469 50
18 Locked 40.3 460 66
19 Locked 40.9 480 37
20 Locked 40.9 389 33
21 Locked 40.9 378 97
22 Locked 40.3 389 38
23 Locked 40.3 338 71
24 Locked 40.9 318 34
1 53699871 5.1 5120 64 qam 2
2 39400014 5.1 5120 64 qam 4
3 46200043 5.1 5120 64 qam 3
4 60300014 5.1 5120 64 qam 1
1 ATDMA 0 0 0 0
2 ATDMA 0 0 0 0
3 ATDMA 0 0 0 0
4 ATDMA 0 0 0 0
General Configuration
Network access Allowed
Maximum Number of CPEs 1
Baseline Privacy Enabled
DOCSIS Mode Docsis30
Config file cxv9873254k;fg87dsfd
SFID 20483
Max Traffic Rate 575000000
Max Traffic Burst 42600
Min Traffic Rate 0
Primary Upstream Service Flow
SFID 20484
Max Traffic Rate 38520000
Min Traffic Rate 0
Max Concatenated Burst 16320
Scheduling Type BestEffort
31/08/2020 14:36:2 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/08/2020 13:18:1 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/08/2020 13:18:1 critical Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/08/2020 13:16:41 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/08/2020 13:16:41 critical Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/08/2020 13:15:21 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/08/2020 13:15:21 critical Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/08/2020 13:14:2 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/08/2020 13:14:1 critical Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/08/2020 13:12:42 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/08/2020 13:12:42 critical Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/08/2020 13:11:22 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/08/2020 13:11:22 critical Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/08/2020 13:10:2 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/08/2020 13:10:2 critical Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/08/2020 13:08:42 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/08/2020 13:08:42 critical Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/08/2020 13:07:22 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/08/2020 13:07:22 critical Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/08/2020 13:05:42 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
SCA1972
  • 5.77K
  • 654
  • 1.94K
Re: Download speed
Downstream channels 6 & 7 have a lot of Post RS errors and the upstream power levels are at the top of the recommended range. These things are not ideal and could result in slower speeds.
You will probably need a technician to visit and adjust the upstream power levels and investigate the cause of the Post RS errors.
You can try to book a visit by calling 150 from a VM landline or 0345 454 1111 from any other phone.
If you can't get through on the phone then VM are recommending you send a text to 07533 051809 describing the issue and you should get a response, but it may take a day or two at present. This is a text only service, it does not support voice calls.
https://community.virginmedia.com/t5/Digital-life/When-and-how-to-use-our-messaging-service/ba-p/425...
Or you can wait for one of the VM forum team to get to this thread, which usually also takes a few days.
______________________
Scott
My setup: V6 TV box, M350 Fibre broadband with Hub 3 in modem mode connected to a Netgear R7000 router. Telewest/VM user since 2001.
sjw444
Re: Download speed
Cheers Scott, i'll try contacting them
Katie_WT
  • 4.84K
  • 293
  • 548
Re: Download speed
Hi there @sjw444
Welcome to our Community and thanks so much for your first post - I was sorry to understand that you've been having some issues with your broadband recently.
After locating your account from your Forum information, we can see that it's been around 3 days since your Hub was rebooted; we have no errors showing and all your signal levels are where we would expect - however, we have identified some network instability which we believe will only be short term.
In the meantime, please do check your connections at home and make sure they're finger tight.
Pop back when you can if you're still having issues in 24/48 hours and we'll go through more checks with you.
Cheers
Katie - Forum Team
sjw444
Re: Download speed
Still having the issue, download speed topping out at 320mb, I'm on the Oomp package and it previously was 600mb. Some router stats to help with diagnosis
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
419000000
0.2
40
256 qam
30
2
187000000
-2.5
40
256 qam
7
3
195000000
-2.2
40
256 qam
8
4
203000000
-2.2
40
256 qam
9
5
211000000
-2.2
40
256 qam
10
6
219000000
-2.2
40
256 qam
11
7
227000000
-2.5
40
256 qam
12
8
235000000
-2.7
40
256 qam
13
9
243000000
-2.5
40
256 qam
14
10
251000000
-2.5
40
256 qam
15
11
259000000
-2.4
40
256 qam
16
12
267000000
-1.7
40
256 qam
17
13
275000000
-1.5
40
256 qam
18
14
283000000
-1.5
40
256 qam
19
15
291000000
-1.4
40
256 qam
20
16
299000000
-1.4
40
256 qam
21
17
307000000
-1.7
40
256 qam
22
18
315000000
-1.5
40
256 qam
23
19
323000000
-1.2
40
256 qam
24
20
379000000
-0.5
40
256 qam
25
21
387000000
-0.5
40
256 qam
26
22
395000000
-0.7
40
256 qam
27
23
403000000
-0.5
40
256 qam
28
24
411000000
0
40
256 qam
29
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
40.9
96
253
2
Locked
40.3
359125
13932
3
Locked
40.3
5802
1322
4
Locked
40.9
5174
1008
5
Locked
40.3
5104
991
6
Locked
40.9
5064
1138
7
Locked
40.3
5307
1514
8
Locked
40.3
5460
1742
9
Locked
40.9
5862
1585
10
Locked
40.3
5873
1360
11
Locked
40.3
5243
1003
12
Locked
40.3
4407
531
13
Locked
40.3
3618
317
14
Locked
40.3
2770
269
15
Locked
40.3
2033
202
16
Locked
40.3
1536
203
17
Locked
40.9
1251
178
18
Locked
40.3
1173
134
19
Locked
40.3
1231
153
20
Locked
40.3
207
152
21
Locked
40.3
153
161
22
Locked
40.9
146
271
23
Locked
40.3
104
157
24
Locked
40.3
115
167
24/09/2020 08:59:49
notice
24/09/2020 00:30:59
critical
23/09/2020 23:39:30
Warning!
RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/09/2020 23:06:18
critical
SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/09/2020 12:24:21
critical
22/09/2020 12:24:21
critical
22/09/2020 12:21:22
critical
22/09/2020 12:21:21
critical
Loads more similar critical type messages every time I’m on-line
Lisa_CC
  • 3.96K
  • 236
  • 436
Moderator
Moderator
Re: Download speed
Hi @sjw444,
I'm sorry that you're still experiencing speed issues and I've had a look at your details and can see that everything looks fine and within range. Your upstream power, although it's not over the high parameters, looks like it's hitting the high range and with real time fluctuations, it may affect your speeds so I've arranged for an engineer visit to take a look.
You may find the details via your online account where you can re-arrange it if necessary. Do pop back and let us know how it goes.
Lisa
