pdhurd2015
  • 26
Download speed very slow
28th Nov 2020. Upgraded from 100Mb to the new 500Mb broadband package and now I am only getting an average of 88 Mb download.....what is going on with the Liberty Global's service?
Anonymous
Not applicable
Re: Download speed very slow
Wired or wireless?
For wired devices access the HUB on http://192.168.0.1 and navigate to the 'Connected devices' section. Ensure the 'Speed (Mbps)' is 1000 (1Gbps), not 100 (10/100).
pdhurd2015
  • 26
Hi Carl,
re: Downstream bandwidth loss on upgrade?
Answer to your question, Wired: thank you for your advice. It was set to 1000 (1Gbps). (First place I looked when bandwidth dropped)
I don't believe it is at my Router end (though I can't guarantee it's integrity further without diagnostic tools). I would hazard a guess it is more fundamental i.e. configuration not set correctly at the "Distribution Hub or in the Head-end - Management systems?"
My Router has been performing robustly, circa 95+%, without intervention for a couple of years (minimal resets)...but then suddenly dropped in Bandwidth (ave 88Mb from an ave110Mb ) directly coinciding with the upgrade  from 100Mb to 500Mb. Incidently, the upstream bandwidth has increased as per expected
