Dave240876
Message 1 of 9
Download speed terrible
  • 516mbps Oomph bundle plan installed 23rd oct, not hit minimum speed 258mbps once since,not even half of that, reset twice no difference, cant get hold of anyone at virgin, shocking want it ripping out ASAP
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 9
Re: Download speed terrible
What speed do you get at >> speedtest.net << with a direct connection using a Cat 5E/6 cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Dave240876
Message 3 of 9
Don't know but did a sleed test sunday 112mbps,mon 42.7,tues 40.8 Tues after reset 114,weds 74 my minimum is 258
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 4 of 9
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting your district. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Then
Can you please
Dave240876
Message 5 of 9
I have checked no problems in area, tbh why should I have to do all this trouble shooting ive only had it a week????
Customer service is an absolute disgrace, I have checked all connections, no problems in my area, reset twice and still download speeds cant even get half of my minimum,
I want someone to remove this broadband and terminate my contract immediately as per contract terms for not hitting min speed,
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 6 of 9
You came onto this community forum with a problem, to help get an overall picture of the status of your Hub and connection we ask for information.
You don't have to do anything if you don't want to.
Let us know either way then we can go forward or ignore your thread.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 7 of 9
@Dave240876 wrote:
... snip ...
You can either phone in (08:00 is the best time) or wait on here for a few days (6 to 7 days average) until one of the VM Forum Staff comes along.
Paul_DN
  • 6.32K
  • 363
  • 659
Message 8 of 9
Hi Dave240876,
Thank you for reaching out ton us in our community and welcome, I am sorry to hear your thinking of leaving due to not receiving the expected Wi-Fi speed.
I have had a look at things our end and cannot see any issues at all, to get a correct speed test result I advise putting the router into modem mode only plug one device in, this must be a device with a gigabit network card using a cat 6 or above cable, when running the test use speedtest.net.
Paul.
jpeg1
  • 4.78K
  • 264
  • 772
Superstar
Message 9 of 9
Dave240876 you haven't confirmed yet that you are using a wired ethernet connection for your tests.  Are you?  Speeds over WiFi are variable and not guaranteed.
