VirulentPip
  • 10
Download speed plummeted
For the last few hours my connection has been really slow (Have M650).. Checked the hub logs and saw all these errors? Will a simple hub restart fix?
  • 5.93K
  • 495
  • 1.5K
Re: Download speed plummeted
You need to post all the power levels, Pre and PostRS errors and Network log as text.  Just copy and paste.
You should have 0 PostRS errors in an ideal world.  Reset the Hub and keep an eye on the PostRS errors, if they build up quickly, you have an issue with the circuit.  Also all speed tests should be done cabled directly to the Hub, NOT over wifi.
jpeg1
  • 6.68K
  • 344
  • 1.22K
Legend
And check that the ethernet connection to your measurement device is running at 1Gb, not 100Mb.  That is a common cause of speeds dropping to the 90's.
