Thanks for coming back to us Turner1944,
We understand the frustration these speeds are causing you, especially as you have tried the speed test on a wired connection and already performed a pin hole reset and it has not improved the services.
Remotely looking from our end with the details you have provided from your community profile we have located you account and done dome further checks from our end.
Currently everything is looking as it should, there are no power level issues, or SNR issues, no area faults that could be affecting you.
Have you performed a speed test via the Ethernet cable this morning?
Kind regards Jodi.
