Vani935
  • 49
Message 1 of 17
Download speed is great, upload speed is poor!
I'm a streamer and I have not been able to stream in almost a month and it's taking the **bleep** now, we gotten a hub 3 and hoping that would sort this issue, turns out it didn't, we got an engineer to sort out what could be the problem, it got fixed for an hour only to go back to being slow again, this is not right, I rebooted it and no changes, with the speed I get I can barely stream at all, not even in 720p 30fps,
I have the package 100mbps and the upload speed I should be getting is around 10mbps but I barely reach even 5 and that's not on at all. I stream on the ethernet so I can get the best possible speed and I'm not even getting it at all, I've been asking for almost a month and nothing has helped besides the engineer which worked for about an hour. Is there a fault in my area? if so please get it fixed or just get me the Hub 4 or something because this is getting silly now, because of this it's making me quit my part-time job as a streamer because of this pandemic I've lost my job because of it. I don't want to quit streaming as I've met so many people and make a bit of money on the side of it and it's made me happy, but with this going on I have not been able to stream for almost a month. The picture below is the upload speed I get and it's on wired, what's strange is that it goes to 10mbps when it's nearly midnight
Anonymous
Not applicable
Message 2 of 17
Re: Download speed is great, upload speed is poor!
Could you access your router using http://192.168.0.1/ . Don't log in, select the 'Check Router Status' option and paste your 'Downstream', 'Upstream', and 'Network Log' tabs?
VM, unlike download, don't guarantee a minimum upload speed. If there is an over subscription (Too many users) in the area this could cause you problems.
Vani935
  • 49
Message 3 of 17
1138750000540256 qam1
21467500005.440256 qam2
31547500005.140256 qam3
4162750000540256 qam4
51707500004.940256 qam5
61787500004.640256 qam6
71867500004.440256 qam7
81947500004.540256 qam8
92027500004.540256 qam9
102107500004.440256 qam10
112187500004.140256 qam11
122267500004.440256 qam12
132347500004.140256 qam13
14242750000440256 qam14
152507500004.340256 qam15
162587500004.540256 qam16
172667500004.540256 qam17
182747500004.540256 qam18
192827500004.940256 qam19
202907500004.940256 qam20
21298750000540256 qam21
223067500005.140256 qam22
233147500005.640256 qam23
243227500005.640256 qam24
1Locked40.34750
2Locked40.34610
3Locked40.95660
4Locked40.94980
5Locked40.35070
6Locked40.35580
7Locked40.36820
8Locked40.96100
9Locked40.36000
10Locked40.97620
11Locked40.38480
12Locked40.99280
13Locked40.310440
14Locked40.910530
15Locked40.310570
16Locked40.310700
17Locked40.312290
18Locked40.314490
19Locked40.913650
20Locked40.916000
21Locked40.317650
22Locked40.918000
23Locked40.317950
24Locked40.920210
Vani935
  • 49
Message 4 of 17
1462000004.85512064 qam3
2537000004.725512064 qam2
3603000004.6512064 qam1
4394000004.875512064 qam4
3ATDMA0000
4ATDMA0000
Vani935
  • 49
Message 5 of 17
12/07/2020 14:40:55noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/07/2020 20:43:44criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/07/2020 22:43:48noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/07/2020 18:47:58criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/07/2020 09:19:30noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/07/2020 08:59:53Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/07/2020 08:59:53criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/07/2020 08:59:51Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/07/2020 08:59:51criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/07/2020 08:59:46Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/07/2020 08:59:46criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/07/2020 08:59:45Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/07/2020 08:59:43Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/07/2020 08:59:40criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/07/2020 08:59:32Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/07/2020 08:53:30noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/07/2020 08:51:14Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/07/2020 08:50:16Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/07/2020 08:50:11Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/07/2020 08:50:11criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Vani935
  • 49
Message 6 of 17
I like to add that I have had amazing upload speed for 2 years, it's been stuck at 9-10 upload speed which has been amazing but now since last month it's been this poor.
Anonymous
Not applicable
Message 7 of 17
Those logs look ok so you'll need to wait for a VM staff member to check if there is an oversubscription in the area.
Vani935
  • 49
Message 8 of 17
It must the oversubscription since it's been fine for almost 2 years now and currently this month it's poor
Lisa_CC
  • 3.99K
  • 236
  • 451
Moderator
Moderator
Message 9 of 17
Hello @Vani935,
Thanks for your Private Message. I've posted back publicly in case we need to get other Teams such as Networks to take a look and it will be easier to show this thread to them for any information they may need. I've had a look at the Area Fault Ticket that was in your local area and it was closed yesterday. This may explain why your download speeds has gone back to normal however I've also taken out my magnifying glass to check over your details and can see some issues on the network. It may be unrelated to the first one but I've notified them for High Utilisation on two upstream channels and have asked them to take a look.
I'm sorry for the ongoing issues and thank you for your continued patience.
Lisa
Vani935
  • 49
Message 10 of 17
Okay, let me know if they get back!
