Capnbob716
Download speed extremely variable
The download speeds at the moment appear extremely variable. We usually have speeds of 250-300mbps but currently it’s often as low as 50-70.
Are these issues likely to be due to high usage by higher numbers being at home during lock down?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Re: Download speed extremely variable
A bit more information is required, please post the following ...
Please do this before posting the Hub Data
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
Copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs onto here, if you get a yellow / straw box warning click the Post button again.
Use one post for each tab if you wish.
Please do not use screen shots.
