arinigo
  • 9
Message 1 of 14
Download speed 1.8 MB, upload speed 0MB on 100MB package
I am getting Download speed 1.8 MB, upload speed 0MB on 100MB package in Glasgow.  Connections keeps dropping since Friday. What is happening with VM?
Anonymous
Not applicable
Message 2 of 14
Re: Download speed 1.8 MB, upload speed 0MB on 100MB package
Not sure what you mean?
Why don't you post your HUB stats like you did last time?
arinigo
  • 9
Message 3 of 14
Carl_Pearce, Yes, should have done, but forgot how I did that last time, and I need to search internet for that. Looks like now I am getting full speed now. I will post the HUB stats once I figure out
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 4 of 14
Then
Can you please
arinigo
  • 9
Message 5 of 14
12030000005.140256 qam9
22110000005.140256 qam10
3219000000540256 qam11
4227000000540256 qam12
5235000000540256 qam13
6243000000540256 qam14
7251000000540256 qam15
82590000004.840256 qam16
92670000004.940256 qam17
102750000004.840256 qam18
112830000004.840256 qam19
122910000004.940256 qam20
13299000000538256 qam21
14307000000540256 qam22
15315000000538256 qam23
16323000000538256 qam24
17331000000538256 qam25
183710000004.840256 qam26
193790000004.940256 qam27
203870000004.840256 qam28
21395000000540256 qam29
224030000004.840256 qam30
23411000000540256 qam31
244190000004.940256 qam32
1Locked40.32350
2Locked40.3670
3Locked40.3550
4Locked40.31780
5Locked40.3470
6Locked40.3600
7Locked40.91380
8Locked40.3460
9Locked40.3320
10Locked40.9430
11Locked40.3440
12Locked40.3800
13Locked38.9610
14Locked40.3630
15Locked38.9670
16Locked38.9690
17Locked38.9450
18Locked40.31470
19Locked40.3890
20Locked40.3470
21Locked40.31550
22Locked40.3840
23Locked40.3780
24Locked40.9380
16030000041.8512064 qam1
24620000041.5512064 qam3
33940000041.5512064 qam4
45370000041.8512064 qam2
1ATDMA0010
2ATDMA0020
3ATDMA0030
4ATDMA0020
arinigo
  • 9
Message 6 of 14
My BQM
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 7 of 14
Can you post the Network Log as well please.
SCA1972
  • 5.89K
  • 662
  • 2K
Message 8 of 14
@arinigo Your speed test images have been rejected as they contains your WAN IP address and this is against the forum rules, to protect your privacy.  If you use the share options on the speed test results page you can add a link or embed an image of your results without your IP address.
Like this:
______________________
Scott
My setup: VM TV box, M350 Fibre broadband with Hub 3 in modem mode connected to a Netgear R7000 router. Telewest/VM user since 2001.
arinigo
  • 9
Message 9 of 14
Time
Priority
Description
24/10/2020 13:51:37
critical
No Ranging Response received - T3 time-out;CM-MAC=xxxxxxxxxxxxx:;CMTS-MAC=xxxxxxxxxxxxxx;CM-QOS=1.1;CM-VER=3.0;
24/10/2020 13:39:14
notice
LAN login Success;CM-MAC=xxxxxxxxxxxxxxxxx;CMTS-MAC=xxxxxxxxxxxxxxxxxx;CM-QOS=1.1;CM-VER=3.0;
23/10/2020 22:20:29
critical
No Ranging Response received - T3 time-out;CM-MAC=xxxxxxxxxxxxxxxxx;CMTS-MAC=xxxxxxxx;CM-QOS=1.1;CM-VER=3.0;
23/10/2020 01:21:31
Error
DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=xxxxxxxxxxx:dd:c3;CMTS-MAC=xxxxxxxxxxxxxx;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 21:22:22
critical
No Ranging Response received - T3 time-out;CM-MAC=xxxxxxxxxxxxxxxxxx;CMTS-MAC=xxxxxxxxxxxxxx;CM-QOS=1.1;CM-VER=3.0;
20/10/2020 02:02:33
Error
DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=xxxxxxxxxxxxx;CMTS-MAC=xxxxxxxxxxxxxxxx;CM-QOS=1.1;CM-VER=3.0;
20/10/2020 02:02:31
Error
DHCP RENEW sent - No response for IPv4;CM-MAC=xxxxxxxxxxxxxxxxxx;CMTS-MAC=xxxxxxxxxxxxx;CM-QOS=1.1;CM-VER=3.0;
17/10/2020 11:52:46
critical
No Ranging Response received - T3 time-out;CM-MAC=xxxxxxxxxxxxxx;CMTS-MAC=xxxxxxxxxxx;CM-QOS=1.1;CM-VER=3.0;
17/10/2020 09:28:44
notice
CMTS-MAC=xxxxxxx;CM-QOS=1.1;CM-VER=3.0;
17/10/2020 09:27:56
Warning!
LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=xxxxxxxxxxxxx;CMTS-MAC=xxxxxxxxxxxxxxxxx;CM-QOS=1.1;CM-VER=3.0;
16/10/2020 07:25:35
critical
16/10/2020 05:01:27
Error
DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=xxxxxxxxxxxxxxxxxxx;CMTS-MAC=xxxxxxxxxxxxx;CM-QOS=1.1;CM-VER=3.0;
15/10/2020 16:47:53
critical
No Ranging Response received - T3 time-out;CM-MAC=xxxxxxxxxxxxxx;CMTS-MAC=xxxxxxxxxxxxxxxx;CM-QOS=1.1;CM-VER=3.0;
14/10/2020 02:41:25
notice
SW download Successful - Via NMS
14/10/2020 02:38:19
notice
SW Download INIT - Via NMS
12/10/2020 10:03:5
critical
No Ranging Response received - T3 time-out;CM-MAC=xxxxxxx;CMTS-MAC=xxxxxxxxxxx;CM-QOS=1.1;CM-VER=3.0;
11/10/2020 07:19:35
Error
DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=xxxxxxxxxxxxxx;CMTS-MAC=xxxxxxxxxxx;CM-QOS=1.1;CM-VER=3.0;
09/10/2020 00:59:42
critical
No Ranging Response received - T3 time-out;CM-MAC=xxxxxxxxxxxxxx;CMTS-MAC=xxxxxxxxxx;CM-QOS=1.1;CM-VER=3.0;
07/10/2020 19:19:35
Error
DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=xxxxxxxxxxxxxxxxx;CMTS-MAC=xxxxxxxxxxx;CM-QOS=1.1;CM-VER=3.0;
04/10/2020 13:10:22
critical
No Ranging Response received - T3 time-out;CM-MAC=xxxxxxxxxxxx;CMTS-MAC=xxxxxxxxxxxxx;CM-QOS=1.1;CM-VER=3.0;
arinigo
  • 9
Message 10 of 14
Thank you.
