Docherty1972
Message 1 of 5
Download Speeds less than 100 kbps!
For the last 3 months my Virgin Media download speeds are getting slowly worse. Less than 100kbps and has been as low as 6kbps!!!! Even when it works properly the connection an speed is so erratic and it can go from 100mb one minute and drop back down to kilobytes within a matter of seconds! Is anybody else experiencing this? Thanks
Buffer6
  • 10.38K
  • 92
  • 612
Hero
Message 2 of 5
Re: Download Speeds less than 100 kbps!
Click on Check service status at the top right of the page to see if there is anything relevant to your location
Docherty1972
Message 3 of 5
Thanks for your response buffer. There is nothing showing up under service status for my region.
When I had this problem before nothing showed up either for months despite the erratic speeds and drop outs before a senior engineer at the exchange realised that the new fibre was overheating. When it works properly it's great but it's so unstable and unreliable these days!
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 4 of 5
How are you connecting your device, Wi-Fi or ethernet cable ?
Go round all the accessible co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Then
Can you please
Martin_N
  • 5.28K
  • 222
  • 302
Message 5 of 5
Hi Docherty1972,
Thank you for your post and welcome to the community.
I'm very sorry to hear about the issue you're having.
Have you been able to try the tests advised by MikeRobbo?
^Martin
