jordand77
  • 10
Message 1 of 11
Download Speed ok but Upload is low or non-existent at times
The issue started around the end of the last week, the download speed is fine between 150 mbps to 200 mbps, the upload speed is 2-3 mbps instead of the usual 20 mbps.
Tried different speed tests, all say the same.
Tried to reset/restart the router also made sure any cables are properly connected, nothing improved.
Was not able to reach anyone from virgin via phone or chat...
Ran tests of both wifi and ethernet pc and they say the same.
Running the test from my logged virgin media account give and error  but when checking my postcode for any issues it says everything is good.
Spoiler
Service status
Network issue
We have detected an issue that maybe affecting your broadband
What does this mean?
  • This issue is caused by interference on our network impacting multiple customers in your area.
  • This will cause intermittent speeds and performance may vary at different times.
  • Our Network teams are aware of this issue and further details on resolution will be available as soon as possible.
Spoiler
Downstream bonded channels Channel Frequency (Hz) Power (dBmV) SNR (dB) Modulation Channel ID
133075000016.837256 qam25
22347500001637256 qam13
324275000015.837256 qam14
42507500001637256 qam15
52587500001637256 qam16
62667500001637256 qam17
727475000015.637256 qam18
828275000015.837256 qam19
929075000015.937256 qam20
1029875000016.336256 qam21
1130675000016.337256 qam22
1231475000016.537256 qam23
1332275000016.637256 qam24
1439475000017.337256 qam26
1540275000017.337256 qam27
1641075000017.137256 qam28
1741875000017.137256 qam29
1842675000017.337256 qam30
194347500001737256 qam31
204427500001737256 qam32
214507500001737256 qam33
2245875000017.137256 qam34
2346675000017.337256 qam35
2447475000017.337256 qam36
Downstream bonded channels Channel Locked Status RxMER (dB) Pre RS Errors Post RS Errors
1Locked37.3190
2Locked37.3180
3Locked37.6160
4Locked37.380
5Locked37.3140
6Locked37.3140
7Locked37.3240
8Locked37.6270
9Locked37.3160
10Locked36.3210
11Locked37.3120
12Locked37.6140
13Locked37.6250
14Locked37.6210
15Locked37.6230
16Locked37.380
17Locked37.6200
18Locked37.6700
19Locked37.34390
20Locked37.354150
21Locked37.610731
22Locked37.63822
23Locked37.3440
24Locked37.3410
Spoiler
Upstream bonded channelsChannel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID
1394000594.55512064 qam2
2326000194.625512064 qam3
3258000404.65512064 qam4
4462000504.525512064 qam1
Upstream bonded channels Channel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
3ATDMA0000
4ATDMA0000
jordand77
  • 10
Message 2 of 11
Re: Download Speed ok but Upload is low or non-existent at times
Spoiler
Network LogTime Priority Description
10/07/2020 13:43:37criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/07/2020 13:37:50noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/07/2020 08:42:52criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/07/2020 08:39:54noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/07/2020 07:13:27criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/07/2020 06:27:6Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:35criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/07/2020 18:41:16noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:36criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/07/2020 13:13:36Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/07/2020 19:17:24criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/07/2020 19:07:41Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/07/2020 12:08:12criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/07/2020 10:16:9noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/07/2020 21:57:58criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/07/2020 04:30:13Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/06/2020 10:11:27criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/06/2020 06:27:25noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/06/2020 12:56:57Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/06/2020 12:18:51ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Anonymous
Not applicable
Message 3 of 11
Your downstream power levels are way too high!
jordand77
  • 10
Message 4 of 11
What am I supposed to do about that? I never changed anything and this is what it shows after a reset.
UPDATE at the moment of writing this my upload speed is 0.4 mbps, lowest ever
Anonymous
Not applicable
Message 5 of 11
It will require help from the VM staff on here, or even an engineer visit.
They should respond in the next few days, however don't bump your thread as it will go to the bottom of the queue!
John_GS
  • 9.18K
  • 494
  • 831
Message 6 of 11
Hi jordand77,
Thanks for posting and welcome to the community. My apologies for the broadband issues. I have checked the system today and there is an area fault causing this. The fault is SNR (signal to noise ratio) and the fault reference is F008204790. The estimated fix date is July 14th 2020.
Kind regards,
John_GS
jordand77
  • 10
Message 7 of 11
Thank you John, I would like to mention that on Friday evening and Saturday 11th of July the upload speed worked fine, however as from today is back to low speeds.... will be waiting until 14th of July then.
jordand77
  • 10
Message 8 of 11
This is happening again... unbelievable, the speeds were ok for the past 2 weeks and now it started again?
What else is going on now?
ravinestan
  • 49
  • 5
Message 9 of 11
This is happening to me too. It was fine up until yesterday.
It's sickening because Speedtest shows things are okay but real world tests with Wetransfer and streaming give me less than 20% of the advertised rate.
jordand77
  • 10
Message 10 of 11
Exactly same stuff, speedtest is unreliable this morning it was like 6mbps now it's 3mbps, it's getting worse and worse, impossible to do any kind of upload...
