Vani935
  • 49
Message 1 of 9
Download Speed and Upload Speed is VERY slow
We been having this issue for a few weeks now, I haven't been able to live stream, having to keep switching the ethernet cable to my PC and Console all the time and it's getting ridiculous. I tried calling up the team but we get stuck on the line for almost forever, I need help fast as it's frustrating. I have two pictures of the speeds from both Wired and Wireless, Wired doesn't change the upload speed at all besides Download, Wireless, however, is THE worst speed possible.
Tags (3)
Vani935
  • 49
Message 2 of 9
Re: Download Speed and Upload Speed is VERY slow
1330750000040256 qam25
2266750000-1.540256 qam17
3274750000-1.538256 qam18
4282750000-1.240256 qam19
5290750000-140256 qam20
6298750000-0.740256 qam21
7306750000-0.540256 qam22
8314750000-0.440256 qam23
9322750000-0.240256 qam24
103707500000.540256 qam26
113787500000.540256 qam27
123867500000.440256 qam28
133947500000.540256 qam29
144027500000.540256 qam30
154107500000.540256 qam31
164187500000.440256 qam32
174267500000.540256 qam33
184347500000.240256 qam34
19442750000040256 qam35
20450750000-0.238256 qam36
214587500000.238256 qam37
224667500001.740256 qam38
234747500001.740256 qam39
244827500001.440256 qam40
1Locked40.3306410
2Locked40.318895157
3Locked38.9206755
4Locked40.3211400
5Locked40.92386210
6Locked40.3250400
7Locked40.3243130
8Locked40.3258810
9Locked40.3285790
10Locked40.9395034
11Locked40.94618913481
12Locked40.352724648
13Locked40.35746310
14Locked40.3651060
15Locked40.3739620
16Locked40.3724760
17Locked40.3784140
18Locked40.3894910
19Locked40.3911510
20Locked38.91074680
21Locked38.91127560
22Locked40.31203020
23Locked40.91383620
24Locked40.31460790
Vani935
  • 49
Message 3 of 9
1462000204.775512064 qam3
2537000004.7512064 qam2
3603000004.6512064 qam1
4394000254.8512064 qam4
3ATDMA0000
4ATDMA0000
Vani935
  • 49
Message 4 of 9
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-rtsl10016u-b.cm
SFID758784
Max Traffic Rate117000047
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID758783
Max Traffic Rate10500047
Max Traffic Burst16320
Min Traffic Rate0
Max Concatenated Burst16320
Scheduling TypeBestEffort
Vani935
  • 49
Message 5 of 9
04/07/2020 20:00:11noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/07/2020 19:52:57criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/07/2020 14:23:28noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/07/2020 04:33:18criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/07/2020 19:49:27Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/07/2020 15:17:7criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/06/2020 19:33:21noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/06/2020 19:32:49Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/06/2020 16:59:57noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/06/2020 16:58:46Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/06/2020 14:19:49noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/06/2020 14:08:21noticeSW download Successful - Via Config file
30/06/2020 14:06:22noticeSW Download INIT - Via Config file
01/01/1970 00:01:45criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/03/2020 08:48:1noticeUnit has been restored to factory defaults from a software issued command;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:50criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/09/2019 16:51:0criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/09/2019 16:48:57Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/09/2019 16:48:53criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/09/2019 16:48:52Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Andrew-G
  • 6.08K
  • 1.07K
  • 2.56K
Message 6 of 9
Network log confirms problems, and the downstream error counts look high.  When was the hub last rebooted?
Vani935
  • 49
Message 7 of 9
Yesterday before sending this log
Steven_L
  • 4.62K
  • 338
  • 458
Message 8 of 9
Sorry to hear that you're having issues with Vani935
I can take a further look into your account but would need to do this by private message, so that we can clear account security and confirm your details.
I will drop the private message over in a moment, so that we can get it sorted for you.
Steven_L
Lisa_CC
  • 3.96K
  • 236
  • 433
Moderator
Moderator
Message 9 of 9
Thanks @Vani935 for joining us in a Private Message and I'm sorry about the ongoing connection problem. I've had a look at the fault ticket  F008259029 to see if there is an update and can confirm that it's still open. The estimated fix time is 12/08 and I'm sorry about this. Some faults takes a little longer for us to fix but our team is aware of it and will aim to fix it as soon as they can.
Please wait till after the date and let us know if you're still having problems so we can check again.
Lisa
