Jaffrtid
Download Speed Slow
I am on 200 mbps deal in Postcode RM15 & speed has been solid for years - in the last 10 days I have had a similar problem to some other posters.
My hub is set to modem & wifi is through an Asus nighthawk,on speedtest I am getting the following average around 70% of the time - Ping 10 ms Dload 7-10mbps Upload  17-20 mbps,on every test ping & Upload are consistent- on the remaining 30%  I get 150 mbps up to top speed.
I have pin reset both modem & router and changed the Hub back to router mode to speed test over ethernet cable & still get the same results.
The website shows no issues in my area & the 'run test' came back with no problems.
Appreciate any assistance.
411000000
Locked
Ranged Upstream Channel (Hz)
39399976
Locked
Provisioning State
Online
Downstream bonded channelsChannel Frequency (Hz) Power (dBmV) SNR (dB) Modulation Channel ID
1411000000-9.237256 qam33
2219000000-10.225256 qam11
3227000000-10.427256 qam12
4235000000-10.236256 qam13
5243000000-10.736256 qam14
6251000000-10.736256 qam15
7259000000-10.436256 qam16
8267000000-9.736256 qam17
9275000000-9.536256 qam18
10283000000-9.237256 qam19
11291000000-9.237256 qam20
12299000000-8.537256 qam21
13307000000-8.237256 qam22
14315000000-8.437256 qam23
15323000000-8.737256 qam24
16347000000-8.537256 qam25
17355000000-8.737256 qam26
18363000000-8.737256 qam27
19371000000-937256 qam28
20379000000-9.437256 qam29
21387000000-9.437256 qam30
22395000000-9.236256 qam31
23403000000-9.437256 qam32
24419000000-9.237256 qam34
1Locked37.324713
2Locked25.7-874734981267812309
3Locked27.314301029313367071
4Locked36.35396371735
5Locked36.35174751
6Locked36.3365566243
7Locked36.34154420
8Locked36.637732786
9Locked36.637959660
10Locked37.333493959
11Locked37.6145146140
12Locked37.327666378
13Locked37.6328525371
14Locked37.61369890
15Locked37.61245858
16Locked37.345781145
17Locked37.64748206
18Locked37.63819232
19Locked37.3843128
20Locked37.391268
21Locked37.62068243
22Locked36.6116629
23Locked37.6304847
24Locked37.3407
0
Upstream bonded channelsChannel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID
1393999765.7512064 qam4
Upstream bonded channelsChannel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
DJ_Shadow1966
  • 6.64K
  • 1.27K
  • 1.81K
Re: Download Speed Slow
Hello
You downstream power levels are too high on a number of channels, as well as a high number of post RS errors, in cases like this can be caused by noise, and can sometimes be fixed by going around and making sure that all coaxial connection to all VM equipment are finger tight, power off hub for 30 secs and then back on. If the power levels are above +10 or getting a lot of Post RS errors then an engineer is going to be need to resolve the issue.
Regards Mike
Jaffrtid
Thanks Mike,no improvement unfortunately so I guess I need a call out.
Kr,
Dave
jpeg1
  • 4.18K
  • 235
  • 667
Community elder
The downstream levels are too LOW, not too high. But you do need a visit to put this right.
gary_dexter
  • 28.71K
  • 1.75K
  • 3.74K
Do you have an attenuator fitted to the back of the hub?
Jaffrtid
Not as far as I know,the cable runs straight into the hub.
