Anonymous
Not applicable
Download Speed Normal, Upload Speed Slow
So I have been having this issue which I have noticed lately, where my download speed is normal, but my upload speed (which is usually at 20mb/s) throughout most of the day drops to anywhere between 1.5 and 10 mb/s, usually on the lower end. I have tried resetting the router, and all tips on the virgin media website, however this has not fixed the issue. I am also on ethernet. I have performed a speed test with the website SamKnows and from that, I am seeing that the speed to my router is also this slow. The peculiar thing is that it randomly and suddenly returns to normal at some point during the evening. Would appreciate it if anyone could help 🙂
Tags (1)
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Re: Download Speed Normal, Upload Speed Slow
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
Copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs onto here, if you get a yellow / straw box warning click the Post button again.
Use one post for each tab if you wish.
audetto74
  • 143
  • 17
Dialled in
Same happened to me since the first lockdown.
I suspect there is nothing random in it, either VM intentionally limiting the speed or over utilisation during work & school hours.
For me it only (& always) happens to upload speed, never to download speed.
Had plenty of visits form VM who fixed signal strength multiple times, but never fixed it properly.
