Tallyberto
  • 23
Message 1 of 14
Download Speed Issue
Hi All,
I am on the 350mb package which for a long time has been perfect. However, the last two days, I am only getting a max of 35mb d/l. My u/l is fine at around 36-37mb.
I am running (as I always have) the VM Router in Modem mode.
Speed Test ResultsSpeed Test ResultsVM RouterVM Router
I am running the HUB 3.0 and its connected to a NETGEAR R6800
Anyone have any ideas please?
Anonymous
Not applicable
Message 2 of 14
Re: Download Speed Issue
@Tallyberto wrote:
Hi All,
You have a SNR issue causing the 1000's of errors on your downstream channels.
It could be a local area issue, or your specific line has a problem.
Tallyberto
  • 23
Message 3 of 14
Hi Carl,
OK thank you - I guess I need to ring VM then. Is SNR something they will be familiar with? I had a massive headache last year trying to get them to understand my upload channels should be 4 when I only had 1 (was getting 12 up instead of the 37 I am now).
Thank you
Anonymous
Not applicable
Message 4 of 14
@Tallyberto wrote:
Hi Carl,
Thank you
They'll do a check on the line, which should hopefully show the issue.
Could you please create a BQM (Broadband Quality Monitor) here, and post the live link?
The BQM will show how good/bad the line is so we can check it over if you have issues with the call centre.
Tallyberto
  • 23
Message 5 of 14
OK, I have set this up, hopefully this will work
https://www.thinkbroadband.com/broadband/monitoring/quality/share/fa9874a60177f44afa05ac5dafdcd5e571b5bd1f]My Broadband Ping
Anonymous
Not applicable
Message 6 of 14
[url=https://www.thinkbroadband.com/broadband/monitoring/quality/share/fa9874a60177f44afa05ac5dafdcd5e571... Broadband Ping[/url]
The link is broken.
I believe this is correct:
It takes an hour or two to show some meaningful data since it starts when you create it.
Tallyberto
  • 23
Message 7 of 14
OK great, thank you very much - Yes, for some reason, whatever link I posted, the forum said it was invalid HTML. I will leave it a few hours to grab data then I will ring VM
Anonymous
Not applicable
Message 8 of 14
Regarding contacting VM you have three options:
  • Wait for a VM staff member to reply on here (Currently 5 - 7 days).
  • Text VM on 07533 051 809.
  • Phone customer services on 0345 454 1111.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 9 of 14
Not forgetting that for VM to test the line the Hub will need to be in Router Mode.
Anonymous
Not applicable
Message 10 of 14
Good point Mike.
Also the OP needs to enable echo requests (Pings) on the Netgear as the BQM is not working (Full red).
