Disconnects and noware near rated Speed or even minimum package speed
Weedkillers
Hiya All
Any advice welcome
I had issues with my M350 account but upgraded to 1.1gbs hoping the new router would help
I have 2 Problems
1.  Intermittent line dropouts still continue (a lot in the past day)
2.  Download speed is still 300-320mbs (not 1.1gbs)   my upload now is 50mbs so that did increase
I’m not an expert but I think I need and engineer and its a possible issue with cable to cabinet
I use cat6e cables and swapped (also tried cat5e)
I have tried in Router mode
Modem Mode with a Asus RT-AC88U router (all my internal network is fine)
Thankyou in advance
03-11-2022 09:41:51
warning
RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=********;CMTS-MAC=******** =1.1;CM-VER=3.1;
03-11-2022 09:41:46
notice
DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=*********;CMTS-********;CM-QOS=1.1;CM-VER=3.1;
03-11-2022 09:41:43
notice
TLV-11 - unrecognized OID;CM-MAC=********;CMTS-MAC=********CM-QOS=1.1;CM-VER=3.1;
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
0
46200000
54.5
5120
QAM 64
1
1
39400000
54
5120
QAM 64
2
2
32600000
53.5
5120
QAM 64
3
3
25800000
53
5120
QAM 64
4
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
0
ATDMA
0
0
0
0
1
ATDMA
0
0
0
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
0
0
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
139000000
0
37
QAM 256
1
2
147000000
0.4
37
QAM 256
2
3
155000000
0.4
36
QAM 256
3
4
163000000
0.5
37
QAM 256
4
5
171000000
0.8
38
QAM 256
5
6
179000000
-1.1
38
QAM 256
6
7
187000000
-1.2
37
QAM 256
7
8
195000000
-1.3
38
QAM 256
8
9
203000000
-1.5
37
QAM 256
9
10
211000000
-1.5
37
QAM 256
10
11
219000000
-1.7
36
QAM 256
11
12
227000000
-1.6
35
QAM 256
12
13
235000000
-1.4
38
QAM 256
13
14
243000000
-1.1
38
QAM 256
14
15
251000000
0.8
38
QAM 256
15
16
259000000
0.9
38
QAM 256
16
17
267000000
0.8
38
QAM 256
17
18
275000000
-1.1
38
QAM 256
18
19
283000000
-1.3
38
QAM 256
19
20
291000000
-1.3
38
QAM 256
20
21
299000000
-1.1
38
QAM 256
21
22
307000000
0.9
38
QAM 256
22
23
315000000
-1
38
QAM 256
23
24
323000000
-1.3
38
QAM 256
24
25
331000000
-1.3
38
QAM 256
25
26
339000000
-1.3
38
QAM 256
26
27
347000000
-1.5
38
QAM 256
27
28
355000000
-1.9
38
QAM 256
28
29
363000000
-2.1
38
QAM 256
29
30
371000000
-2.4
38
QAM 256
30
31
379000000
-2.6
38
QAM 256
31
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
37
78948
93216
2
Locked
37
141882
23107
3
Locked
36
697361
70
4
Locked
37
455705
115
5
Locked
38
13959
222
6
Locked
38
14696
719
7
Locked
37
15130
921
8
Locked
38
15493
620
9
Locked
37
14607
219
10
Locked
37
11335
58
11
Locked
36
6386
23
12
Locked
35
2564
4
13
Locked
38
1328
0
14
Locked
38
1216
0
15
Locked
38
1192
0
16
Locked
38
1182
1
17
Locked
38
1087
0
18
Locked
38
962
0
19
Locked
38
820
0
20
Locked
38
670
0
21
Locked
38
526
0
22
Locked
38
465
0
23
Locked
38
436
0
24
Locked
38
494
0
25
Locked
38
466
0
26
Locked
38
444
0
27
Locked
38
403
0
28
Locked
38
385
0
29
Locked
38
336
0
30
Locked
38
305
0
31
Locked
38
319
2 REPLIES 2
carl_pearce
Trouble shooter
I'd suggest sticking to one thread.
Your upstream channel's power levels are too high, so you'll probably need an engineer visit to sort.
Chris_W1
Hi Weedkillers, thanks for the message and sorry to hear that there is an issue with the broadband.
I will send you a private message so that this can be looked into further.
Kind regards, Chris.
