S11kda
Message 1 of 7
Different broadband speed on computer vs mobile
Just had 100m broadband speed installed, when I use the speed test that Virgin recommended on my phone speed looks perfect, however when I go to my computer and do the same thing its much lower despite the router sitting next to the computer. Have tried call virgin customer service but after being on the phone for 45mins, twice in a week with no answer i give up.
Help
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 7
Re: Different broadband speed on computer vs mobile
Connect an ethernet cable to the Hub & PC and test again at speedtest.net.
S11kda
Message 3 of 7
Thanks much better speed. But I don't really want to plug with an ether cable. Defeat the object of wireless if you get my meaning, any ideas as to why this would happen and what I can do?
Anonymous
Not applicable
Message 4 of 7
What types of wireless card is in the PC?
There are so many standards you can't really compare one device to another.
S11kda
Message 5 of 7
Ah not sure, all I know its HP Ombi200PC
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 6 of 7
If the PC is adjacent to the Hub a cable connection is the fastest, most stable and less prone to interreference than the best Wi-Fi in the world.
Anonymous
Not applicable
Message 7 of 7
https://support.hp.com/gb-en/document/c02987274 ?
Interface type: PCI-e half-length mini card
Data transfer speeds: up to 150 Mbps
Transmission standards: 802.11 b/g/n
Supported antenna connections: 1
Operating band: 2.4 GHz
Supported security protocols:
WPA
WEP
It appears your phone will have a better wireless card than your PC!
