Cyirak
  • 82
Message 1 of 14
Did they not fix the latency issue on the hub 4?
I installed a Hub4 (was hoping for a hub5) yesterday and upgraded from 500 to gig1.
Speeds are fine  getting 945 down through ethernet and 45-52 up. however i noticed that the old latency spikes are back from when i originally signed up to virgin years ago. i belive it was an issue with the intel puma chip the behaviour looks exactly the same to me.
You can see exactly where i swapped the superhub at around 4 pm yesterday
anyone else experienced this? or could there be an issue on my connection causing this?
Tags (3)
Cyirak
  • 82
Message 2 of 14
Re: Did they not fix the latency issue on the hub 4?
Cable Modem Status
Item
Status
Comments
Cable Modem Status
Online
DOCSIS 3.1
Primary downstream channel
Locked
SC-QAM
Channel Overview
Downstream
Upstream
DOCSIS 3.0 channels
31
4
DOCSIS 3.1 channels
1
0
3.0 Downstream channels
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
25
330750000
5.699997
38.983261
QAM256
25
6
178750000
6.400002
38.605377
QAM256
6
7
186750000
6.099998
38.605377
QAM256
7
8
194750000
5.900002
38.605377
QAM256
8
9
202750000
5.699997
38.605377
QAM256
9
10
210750000
5.400002
38.983261
QAM256
10
11
218750000
5.000000
38.605377
QAM256
11
12
226750000
4.500000
38.983261
QAM256
12
13
234750000
4.000000
38.605377
QAM256
13
14
242750000
3.599998
38.983261
QAM256
14
15
250750000
3.099998
38.605377
QAM256
15
16
258750000
3.900002
38.605377
QAM256
16
17
266750000
5.300003
38.983261
QAM256
17
18
274750000
6.000000
38.983261
QAM256
18
19
282750000
6.199997
38.983261
QAM256
19
20
290750000
6.400002
38.983261
QAM256
20
21
298750000
6.000000
38.983261
QAM256
21
22
306750000
5.500000
40.366287
QAM256
22
23
314750000
5.500000
38.983261
QAM256
23
24
322750000
5.599998
40.366287
QAM256
24
26
338750000
5.699997
40.366287
QAM256
26
27
346750000
5.900002
40.366287
QAM256
27
28
354750000
6.099998
40.366287
QAM256
28
29
362750000
6.199997
40.366287
QAM256
29
30
370750000
5.599998
40.366287
QAM256
30
31
378750000
4.800003
38.983261
QAM256
31
32
386750000
4.300003
38.983261
QAM256
32
33
394750000
3.900002
38.605377
QAM256
33
34
402750000
3.900002
38.983261
QAM256
34
35
410750000
4.000000
40.366287
QAM256
35
36
418750000
4.400002
38.983261
QAM256
36
Cyirak
  • 82
Message 3 of 14
Channel
Lock Status
RxMER (dB)
Pre RS Errors
Post RS Errors
25
Locked
38.983261
0
0
6
Locked
38.605377
0
0
7
Locked
38.605377
0
0
8
Locked
38.605377
0
0
9
Locked
38.605377
0
0
10
Locked
38.983261
0
0
11
Locked
38.605377
0
0
12
Locked
38.983261
0
0
13
Locked
38.605377
0
0
14
Locked
38.983261
0
0
15
Locked
38.605377
0
0
16
Locked
38.605377
0
0
17
Locked
38.983261
0
0
18
Locked
38.983261
0
0
19
Locked
38.983261
0
0
20
Locked
38.983261
0
0
21
Locked
38.983261
0
0
22
Locked
40.366287
0
0
23
Locked
38.983261
0
0
24
Locked
40.366287
0
0
26
Locked
40.366287
0
0
27
Locked
40.366287
0
0
28
Locked
40.366287
0
0
29
Locked
40.366287
0
0
30
Locked
40.366287
0
0
31
Locked
38.983261
0
0
32
Locked
38.983261
0
0
33
Locked
38.605377
0
0
34
Locked
38.983261
0
0
35
Locked
40.366287
0
0
36
Locked
38.983261
0
0
3.1 Downstream channels
Channel
Channel Width (MHz)
FFT Type
Number of Active Subcarriers
Modulation (Active Profile)
First Active Subcarrier (Hz)
37
96
4K
1880
QAM4096
759
Channel ID
Lock Status
RxMER Data (dB)
PLC Power (dBmV)
Correcteds (Active Profile)
Uncorrectables (Active Profile)
37
Locked
43
4.0
120153432
0
3.0 Upstream channels
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
32600000
40.020599
5120 KSym/sec
16QAM
5
2
39400000
40.020599
5120 KSym/sec
16QAM
4
3
46200000
39.770599
5120 KSym/sec
32QAM
3
4
25800000
40.270599
5120 KSym/sec
16QAM
6
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
US_TYPE_STDMA
0
0
2
0
2
US_TYPE_STDMA
0
0
0
0
3
US_TYPE_STDMA
0
0
0
0
4
US_TYPE_STDMA
0
0
0
0
I noticed the upstream has gone to a lower modulation. this tends to happen from time to time but normally all channels are at 64QAM
  • 6.08K
  • 511
  • 1.57K
Message 4 of 14
@Cyirak wrote:
<snip>
You have diagnosed the issue yourself as above.  No much you can do except call it in, or wait here a day or two for a VM Mod to respond.
Cyirak
  • 82
Message 5 of 14
Yeah really disappointing. The Latency is horrible, I'll monitor for a few days and wait for a vm mod to respond.
Thanks for taking the time to respond.
Cyirak
  • 82
Message 6 of 14
So appears that there was a fault in my area that was resolved on Monday which was affecting the upload. However, my latency is still much worse and is terrible for gaming, wasn't brilliant before on the 500mb service compared to bt fftc or fttp but acceptable, its now dire.  all upstream channels are now at 64QAM and look to have been since the area issue was resolved.
HUB3 on 500mb day before I swapped over
On Gig1 with Hub 4
Cyirak
  • 82
Message 7 of 14
just noticed this, does this suggest there's a problem, the QAM on the downsteam has dropped to 2048 and there are a bucket load of correcteds.
Cyirak
  • 82
Message 8 of 14
Interestingly reboot of the SH4 (at about 8pm last night) which is in modem mode looks to resolved the issue. it was rebooted about 2 hours after i had swapped over so didn't really expect anything.
  • 6.08K
  • 511
  • 1.57K
Message 9 of 14
The QAM as you point out should be 4096.  As for the PreRS correctable figures, that's okay.  It's the PostRS uncorrectable errors that cause issues
Cyirak
  • 82
Message 10 of 14
Thanks, This seems to have stuck at 4096 since the reboot so fingers crossed its now sorted. i'm also getting the full 52mbps upload where as before i was hitting 40.
Thanks for your help and taking the time to respond.
