Message 1 of 7
Did anyone actually get their m350 broadband up to speed?
Like many posts, I’ve had m350 for a while but it has not been achieving anything like the speeds and Virgin just say restart the router and stuff which is useless. Or it will improve for a bit but then large parts of the day will be sub 30mpbs..
anyone get virgin to actually help? If I reduce down to 100mbps will I get similar speeds or an even more scaled down speed?
  • 20.96K
  • 1.14K
  • 2.7K
Message 2 of 7
Re: Did anyone actually get their m350 broadband up to speed?
Over a wired or wireless connection?
Message 3 of 7
Both - the wireless has more issues and I’m okay with it being lower than the Ethernet but the inconsistency is annoying
  • 20.96K
  • 1.14K
  • 2.7K
Message 4 of 7
What speeds do you get wired?
  • 1.72K
  • 56
  • 218
Super solver
Message 5 of 7
Yes, I get 380Mbps on my 350Mbps service.
Red (VM SH2 AC Beta tester)
Running on 500Mb VM service with SH3 in Modem Mode, with a ASUS RT-AC5300 router. With this setup I get Fantastic WIRED and WIRELESS Signals in my home. I dont work for VM. But I work in IT, and I know my tech.
My advice is at your own risk. If you are happy with my answers please press Kudo ?
Message 6 of 7
So using the sh3 as modem and not modem + router works better for you?
  • 20.96K
  • 1.14K
  • 2.7K
Message 7 of 7
So what speeds do you achieve when wired direct to the hub?
