sadsmileyface
  • 6
Message 1 of 8
Critical's and Warnings in Network Log- what's going on?
I've been experiencing interruptions to service recently which is very unusual, everything is normally very stable. I have a SuperHub 3 in Modem Mode which has been reporting the following in its Network Log;
04/03/2022 20:12:5noticeLAN login Success;
04/03/2022 18:03:8Warning!RCS Partial Service;
04/03/2022 18:00:56criticalSYNC Timing Synchronization failure - Loss of Sync;
04/03/2022 17:52:52Warning!RCS Partial Service;
04/03/2022 17:45:52criticalNo Ranging Response received - T3 time-out;
04/03/2022 17:34:49Warning!RCS Partial Service;
04/03/2022 17:34:43criticalSYNC Timing Synchronization failure - Loss of Sync;
04/03/2022 17:09:25Warning!RCS Partial Service;
04/03/2022 17:09:24criticalNo Ranging Response received - T3 time-out;
04/03/2022 17:09:23Warning!RCS Partial Service;
04/03/2022 17:08:54criticalNo Ranging Response received - T3 time-out;
04/03/2022 13:26:33Warning!RCS Partial Service;
04/03/2022 13:26:14criticalSYNC Timing Synchronization failure - Loss of Sync;
04/03/2022 13:22:35Warning!RCS Partial Service;
04/03/2022 13:21:35criticalNo Ranging Response received - T3 time-out;
04/03/2022 13:04:20Warning!RCS Partial Service;
13310000007.440256 qam25
22350000007.940256 qam13
32430000007.540256 qam14
42510000007.540256 qam15
52590000007.540256 qam16
62670000007.540256 qam17
72750000007.440256 qam18
82830000007.540256 qam19
92910000007.440256 qam20
102990000007.540256 qam21
113070000007.540256 qam22
123150000007.640256 qam23
133230000007.540256 qam24
14339000000740256 qam26
153470000006.640256 qam27
163550000006.440256 qam28
17363000000640256 qam29
18371000000640256 qam30
193790000005.940256 qam31
203870000005.640256 qam32
213950000005.540256 qam33
224030000005.440256 qam34
234110000005.140256 qam35
24419000000540256 qam36
13940000044.5512064 qam4
24620000044.5512064 qam3
35370000034.3512064 qam2
46030000033.3512064 qam1
I'm kind of at a loss as to what I can do about this and the huge reduction in speed that I'm seeing. Does anyone have any ideas?
  • 6.82K
  • 593
  • 1.79K
Message 2 of 8
Re: Critical's and Warnings in Network Log- what's going on?
Looks like an upstream problem, possible noise on the circuit.?
You need to post the Downstream Pre and PostRS errors.   Also setup a BQM here www.thinkbroadband.com/ping
Once done we can comment on the stats.
gitty
  • 257
  • 67
Superfast
Message 3 of 8
There is a 11 dB power difference between the upstream channels (12 dB is the edge). That is not normal, so I agree that there is something going on in the upstream.
sadsmileyface
  • 6
Message 4 of 8
1Locked40.396264978
2Locked40.3304105433
3Locked40.9280515473
4Locked40.3265995545
5Locked40.9249645591
6Locked40.3241925858
7Locked40.3230486150
8Locked40.9201475490
9Locked40.9177235371
10Locked40.9150355804
11Locked40.3125925030
12Locked40.9111544976
13Locked40.3103044966
14Locked40.998144281
15Locked40.995834679
16Locked40.394434074
17Locked40.396374572
18Locked40.390044390
19Locked40.987824254
20Locked40.981064221
21Locked40.372594360
22Locked40.367654498
23Locked40.358084366
24Locked40.953664589
I'm guessing that the dropped packets reported is to do with the router though...
  • 6.82K
  • 593
  • 1.79K
Message 5 of 8
You have to many Post|RS errors and generally this is indicative of noise on the circuit.  Ideally they should be zero.
A VM technician will need to find the problem and fix it.  Wait here a day or two for a VM Mod to pick this up.
sadsmileyface
  • 6
Message 6 of 8
https://www.thinkbroadband.com/broadband/monitoring/quality/share/39e202582b45d7929710a380781cc552aa...
The forum doesn't seem to want to let me embed this in any way so hopefully this link works. The connection has been dreadful tonight, the full thing has been dropping off regularly.
Steven_L
  • 11.33K
  • 689
  • 1.15K
Message 7 of 8
Hey @sadsmileyface,
Welcome back to the community and thanks for taking the time to post your issue on the forums.
I'm sorry to hear of the issues that you're having with your connection at the moment, I have looked into this and can see that there is an issue with the SNR levels on your connection, this would need a technician visit to resolve.
I can arrange the appointment from here but would need to confirm a few details via a private message, that I will drop over in a moment.
Please look out for the private message and we can get started.
Regards,
Steven_L
Steven_L
  • 11.33K
  • 689
  • 1.15K
Message 8 of 8
Thanks for confirming your details via private message @sadsmileyface.
I have arranged for the appointment and you can track your engineer appointments online. Simply sign in to My Virgin Media and you’ll see your appointments on your account dashboard.
Regards,
Steven_L
