Baileyuk81
  • 5
Constantly slow speeds around 20/30mb when paying for 200mb
Recently moved house and despite a speed upgrade it seems much slower across all devices.
Any help greatly appreciated as it's affecting my work.
243000000
Locked
Ranged Upstream Channel (Hz)
46200000
Locked
Provisioning State
Online
Channel           Frequency (Hz)           Power (dBmV) SNR (dB)        Modulation      Channel ID
1          243000000      2.4       38        256 qam          14
2          139000000      3.7       38        256 qam          1
3          147000000      3.5       38        256 qam          2
4          155000000      3.2       38        256 qam          3
5          163000000      3.4       38        256 qam          4
6          171000000      3.7       40        256 qam          5
7          179000000      3.4       38        256 qam          6
8          187000000      3.7       38        256 qam          7
9          195000000      3.4       40        256 qam          8
10        203000000      2.9       38        256 qam          9
11        211000000      2.9       38        256 qam          10
12        219000000      2.7       38        256 qam          11
13        227000000      2.2       38        256 qam          12
14        235000000      2.5       40        256 qam          13
15        251000000      2          38        256 qam          15
16        259000000      2.5       38        256 qam          16
17        267000000      2.7       40        256 qam          17
18        275000000      2          38        256 qam          18
19        283000000      2.5       38        256 qam          19
20        291000000      2.7       38        256 qam          20
21        299000000      2.5       38        256 qam          21
22        307000000      3          38        256 qam          22
23        315000000      3.2       40        256 qam          23
24        323000000      2.5       38        256 qam          24
Channel           Locked Status RxMER (dB)   Pre RS Errors Post RS Errors
1          Locked 38.9     42        0
2          Locked 38.6     19        0
3          Locked 38.9     65        0
4          Locked 38.9     25        0
5          Locked 38.9     56        0
6          Locked 40.3     26        0
7          Locked 38.9     51        0
8          Locked 38.9     74        0
9          Locked 40.3     37        0
10        Locked 38.9     57        0
11        Locked 38.9     44        0
12        Locked 38.9     25        0
13        Locked 38.6     56        0
14        Locked 40.9     61        0
15        Locked 38.6     67        0
16        Locked 38.9     44        0
17        Locked 40.3     28        0
18        Locked 38.9     73        0
19        Locked 38.9     149      0
20        Locked 38.9     35        0
21        Locked 38.9     63        0
22        Locked 38.9     84        0
23        Locked 40.3     100      0
24        Locked 38.6     100      0
Channel           Frequency (Hz)           Power (dBmV) Symbol Rate (ksps)    Modulation      Channel ID
1          46200000        46        5120    64 qam            1
2          39400000        46        5120    64 qam            2
3          25800000        45.8     5120    64 qam            4
4          32600000        46        5120    64 qam            3
Channel           Channel Type T1 Timeouts    T2 Timeouts    T3 Timeouts    T4 Timeouts
1          ATDMA           0          0          1          0
2          ATDMA           0          0          3          0
3          ATDMA           0          0          2          0
4          ATDMA           0          0          0          0
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt060+voc-b.cm
SFID    48540
Max Traffic Rate         230000061
Max Traffic Burst        42600
Min Traffic Rate          0
Primary Upstream Service Flow
SFID    48539
Max Traffic Rate         22000061
Min Traffic Rate          0
Max Concatenated Burst        42600
Scheduling Type         BestEffor
Time    Priority Description
20/01/2021 15:36:41   notice  LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/01/2021 15:35:11   Warning!          LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/01/2021 08:54:47   critical  No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/01/2021 20:54:4     Error    DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/01/2021 07:21:6     critical  No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/01/2021 20:19:23   Error    DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:39   critical  No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/01/2021 01:32:37   notice  SW download Successful - Via NMS
11/01/2021 01:29:14   notice  SW Download INIT - Via NMS
10/01/2021 11:24:35   critical  No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/01/2021 15:03:25   Error    DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/01/2021 09:08:20   critical  No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/01/2021 03:03:24   Error    DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/01/2021 05:01:12   critical  No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/01/2021 01:29:52   Error    DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/12/2020 21:25:25   critical  No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/12/2020 15:37:0     Error    DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/12/2020 06:03:0     critical  No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/12/2020 11:41:32   Error    DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/12/2020 00:00:0     critical  No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
jpeg1
  • 4.2K
  • 235
  • 669
Community elder
Re: Constantly slow speeds around 20/30mb when paying for 200mb
What device are you using to measure the speed, and how is it connected to the Hub?   WiFi speeds are not guaranteed.
Baileyuk81
  • 5
I've tried a variety of devices including laptops on ethernet.
Looking at the log should there be that many errors?
carl_pearce
  • 4.73K
  • 402
  • 706
Superstar
@Baileyuk81 wrote:
HUB stats are fine.
Create a BQM and post the live link.
