Are the speed issues only evident on wifi connections or do you see them at the same times on devices connected on ethernet cables?
If you don't know, can you check to help diagnose whether it is just a wifi issue or it could be network connection related?
Wifi speeds aren't guaranteed and will usually will be way less than that on ethernet cable - if usin the Hub wifi and not your own equipment
