Constant low-level packet loss
tievolu
For the last month or so I've been getting constant low levels of packet loss (note the red signal at the top of the chart):
It doesn't seem to be affecting general day to day usage, but clearly something's not quite right. Rebooting the hub doesn't make any difference. The VM service page isn't working right now but last time I checked it indicated problems with TV in my area, but no issues with broadband.
Any ideas?
1258750000-3.537256 qam16
21387500000.237256 qam1
3146750000037256 qam2
4154750000-0.737256 qam3
5162750000-137256 qam4
6170750000-1.537256 qam5
7178750000-1.937256 qam6
8186750000-2.237256 qam7
9194750000-2.737256 qam8
10202750000-337256 qam9
11210750000-3.537256 qam10
12218750000-3.937256 qam11
13226750000-4.537256 qam12
14234750000-4.737256 qam13
15242750000-4.737256 qam14
16250750000-4.237256 qam15
17266750000-3.937256 qam17
18274750000-3.737256 qam18
19282750000-3.537256 qam19
20290750000-437256 qam20
21298750000-3.737256 qam21
22306750000-3.737256 qam22
23314750000-4.237256 qam23
24322750000-4.237256 qam24
1Locked37.64740
2Locked37.31440
3Locked37.61660
4Locked37.62440
5Locked37.63470
6Locked37.62530
7Locked37.32140
8Locked37.32230
9Locked37.62720
10Locked37.33570
11Locked37.35780
12Locked37.66470
13Locked37.610010
14Locked37.312950
15Locked37.311280
16Locked37.67350
17Locked37.67560
18Locked37.65860
19Locked37.36450
20Locked37.68750
21Locked37.36810
22Locked37.67660
23Locked37.610630
24Locked37.69980
14310000044.5512064 qam2
24959997644.8512064 qam1
33010000044.8512064 qam4
43660000044512064 qam3
52360011047.2512016 qam5
1ATDMA0030
2ATDMA0010
3ATDMA0020
4ATDMA0000
5ATDMA00120
127 REPLIES 127
Firstly, can you also try the “free & automated” Service Status number - 0800 561 0061 - which usually gives the most up to date info. and tells you of more local issues down to street cab/ postcode level - than the area fault web site that covers 1000's of users
I do not work for VM. My services: HD TV on VIP (+ Sky Sports & Movies & BT sport), x3 V6 boxes (1 wired, 2 on WiFi) Hub5 in modem mode with Apple Airport Extreme Router +2 Airport Express's. On Volt 350Mbps, Talk Anytime Phone, x2 Mobile SIM only iPhones.
tievolu
No issues according to the automated service status phone line.
Hi tievolu,
Thanks for posting, and sorry to hear you're having some issues with the Internet.
I've had a look at things from our side and can see the hubs downstream levels are not what they should be.
It's something I'll need to arrange a technician visit for, before I can do this I'll need a few details from you so I've popped you over a private message (purple envelope, top right hand corner)
Alex_Rm
tievolu
The technician came today and said the signal levels looked ok, although it wouldn't take much fluctuation to put them out of spec, so he went to the cabinet to bump the power level up a bit. However, he was unable locate the tone from the telco cable at the cabinet so he couldn't locate the coax cable, which means he was unable to do anything with the signal level.
He recommended a new pull of RG11 cable from the cabinet to my house due to the distance involved (he noted my neighbour's run is already RG11, whereas mine is RG6). Not sure quite how that will go because the ducting on the street isn't visible (presumably buried under the tarmac) and the cable on my property is buried under my drive. I suspect I'm going to end up with a cable in some big ugly ducting laying in my flower bed.
tievolu
The re-pull has actually been done very well. No visible cables on the street, an access point added in the pavement, and they buried the cable in some thin green ducting in the flower bed right up to the house.
Unfortunately they didn't have the right key for the cabinet so they couldn't actually connect the new cable. Hopefully that will be done soon and I should be able to tell pretty quickly if the issue is resolved.
tievolu
I've just been switched over to the new cable. Too early to tell whether it has resolved the packet loss, but here are the new signal levels:
125875000010.538256 qam16
213875000012.637256 qam1
314675000012.537256 qam2
41547500001237256 qam3
516275000011.837256 qam4
617075000011.537256 qam5
71787500001137256 qam6
818675000010.637256 qam7
919475000010.437256 qam8
102027500009.937256 qam9
112107500009.637256 qam10
122187500009.437256 qam11
13226750000937256 qam12
14234750000937256 qam13
152427500009.137256 qam14
162507500001037256 qam15
1726675000010.538256 qam17
1827475000010.937256 qam18
1928275000010.937256 qam19
2029075000010.537256 qam20
2129875000011.337256 qam21
223067500001138256 qam22
233147500001138256 qam23
243227500001138256 qam24
1Locked38.940
2Locked37.600
3Locked37.6160
4Locked37.600
5Locked37.660
6Locked37.600
7Locked37.600
8Locked37.350
9Locked37.650
10Locked37.6110
11Locked37.640
12Locked37.360
13Locked37.650
14Locked37.600
15Locked37.600
16Locked37.670
17Locked38.600
18Locked37.660
19Locked37.650
20Locked37.640
21Locked37.650
22Locked38.660
23Locked38.650
24Locked38.640
14310000033.3512064 qam2
24960000033.3512064 qam1
33660000033512064 qam3
42360016636.8512016 qam5
53010000034512064 qam4
3ATDMA0000
4ATDMA0000
5ATDMA0000
Hey tievolu, thank you for reaching out and I am sorry to hear you are having some connection issues.
I am going to send you a PM, please look out for the purple envelope. Thanks
Matt - Forum Team
New around here?
tievolu
Unfortunately the problem is not resolved. It's been mostly the same since the re-pull, but slightly worse today:
The large spikes of packet loss shown above are due to me trying various things like rebooting the hub, rebooting my router, switching out the coax cable from the wall for a different one etc., so those can be ignored. It's the constant background packet loss that's the problem. The level of packet loss is less than 1%, so it's not significant enough to cause major problems, but clearly something isn't right.
The signal levels all look ok (I think - see post above), and the hub status pages show zero post-RS errors. Given that I've tried switching my internal cabling, had an engineer visit (who said everything looked fine) and even had a complete re-pull from the cabinet, all to no avail, it seems that the problem is somewhere further upstream.
tievolu
I've also just noticed that my upload speed now maxes out at about 4-5Mbps instead of ~35Mbps. Something seems to have changed on Wednesday night or early Thursday morning. This seems to be when the packet loss got worse as well.
