Constant drops and really slow page load times
xSTrAfeRx
I'm new to Virgin Media and so far my experience has been awful. We are getting constant drops throughout the day and even more so in the evenings. It will also sometimes take up to 10 seconds for a simple webpage to load. Gaming is also near on impossible with having constant high latency spikes.
12 REPLIES 12
Try checking with Area faults on 0800 561 0061 or if you have a VM landline 150 as small local faults are not listed on the VM status page.
Post the power levels, Pre and PostRS errors and network log from the Hub. Also setup a BQM to monitor your circuit www.thinkbroadband.com/ping
Once done we can comment.
Hi Adduxi
Here is the router status info:
659000000
Locked
Ranged Upstream Channel (Hz)
49600000
Locked
Provisioning State
Online
16590000009.137256 qam32
24750000007.538256 qam9
3483000000838256 qam10
44910000007.638256 qam11
54990000007.937256 qam12
65070000007.537256 qam13
75150000007.938256 qam14
85230000007.937256 qam15
95310000007.838256 qam16
105390000007.838256 qam17
115470000007.437256 qam18
125550000007.438256 qam19
13563000000737256 qam20
145710000007.437256 qam21
155790000006.937256 qam22
16587000000737256 qam23
175950000007.137256 qam24
18603000000737256 qam25
196110000007.837256 qam26
206190000007.537256 qam27
216270000008.137256 qam28
22635000000837256 qam29
236430000008.537256 qam30
246510000008.837256 qam31
1Locked37.66311589
2Locked38.6955432
3Locked38.91265364
4Locked38.61755010
5Locked37.61245166
6Locked37.61694875
7Locked38.61635321
8Locked37.61575226
9Locked38.61465193
10Locked38.61315252
11Locked37.31645386
12Locked38.98273460
13Locked37.68353375
14Locked37.68623561
15Locked37.68763386
16Locked37.68553455
17Locked37.38863480
18Locked37.68823312
19Locked37.68133480
20Locked37.38633384
21Locked37.67933585
22Locked37.35662343
23Locked37.64962373
24Locked37.65562304
14960000049512064 qam1
22360000047.5512064 qam5
33010000049512064 qam4
43660000049512064 qam3
54310000049512064 qam2
1ATDMA0030
2ATDMA0010
3ATDMA0010
4ATDMA0040
5ATDMA0000
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
vca69834ncxv9873254k;fg87
SFID233
Max Traffic Rate143750047
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID232
Max Traffic Rate22000047
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
17/08/2023 15:23:56criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/08/2023 21:17:6criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/08/2023 21:17:6Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/08/2023 21:17:5criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/08/2023 17:14:23noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/08/2023 17:14:23ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/08/2023 14:58:17Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/08/2023 21:55:28criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/08/2023 05:14:23noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/08/2023 05:14:23ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/08/2023 06:36:31criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/08/2023 00:51:23criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/08/2023 00:51:17criticalDHCP FAILED - Discover sent, no offer received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/08/2023 00:49:35criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/08/2023 00:45:32criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/08/2023 00:26:37criticalNo Maintenance Broadcasts for Ranging opportunities received - T2 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/08/2023 00:26:31Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/08/2023 00:26:27criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/08/2023 00:25:47criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/08/2023 00:25:45Warning!B-INIT-RNG Failure - Retries exceeded;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Too many PostRS errors showing, indicative of noise in the circuit. Also packet loss on the BQM. All you can do is check for local faults and make sure all the connections from outside to inside to your Hub are finger tight. Apart from this, wait here a day or two for a VM Mod to pick this up and discuss.
Hi @xSTrAfeRx
Welcome to our community forums and thank you for your first posts.
Sorry to hear you are having issues with dropouts on your service. This is not the level of service we look to provide especially to our new customers. I have had a look on the system and your hub seems to be having a long run time. Are you able to reboot the hub as seen here? https://virg.in/ConnectHelp This will help us run further tests back end.
Akua_A
Hi Akua_A
I've not been with Virgin Media for a month yet so I don't how it could be classed as having a high run time. Nevertheless I rebooted the hub as requested the other day and have still been experiencing drops and latency issues.
Hi @xSTrAfeRx, thank you for your response.
We're sorry to hear a reboot hasn't made any difference 😔
In order to look into this for you further, we'll send you a private message on here. Look out for the envelope in the top right-hand corner.
Regards,
Daniel
Had an engineer out who fixed a kinked cable in the cabinet. Seemed like it was better for a while but the issues have returned.
I'm still getting the constant drops and latency issues, working from home is near impossible with teams calls constantly having issues. No issues listed on Virgin Media site.
Getting 1000's of Download Post RS Errors:
15150000001138256 qam14
241100000010.637256 qam1
341900000010.937256 qam2
44270000001137256 qam3
543500000011.137256 qam4
64430000001137256 qam5
74510000001138256 qam6
845900000010.537256 qam7
946700000010.637256 qam8
1047500000010.837256 qam9
1148300000010.937256 qam10
124910000001138256 qam11
1349900000010.938256 qam12
1450700000010.937256 qam13
155230000001138256 qam15
1653100000010.938256 qam16
1753900000010.937256 qam17
1854700000010.537256 qam18
1955500000010.338256 qam19
2056300000010.538256 qam20
2157100000010.337256 qam21
2257900000010.337256 qam22
235870000001037256 qam23
2459500000010.337256 qam24
1Locked38.65562456
2Locked37.6603684
3Locked37.61103757
4Locked37.61113835
5Locked37.6963743
6Locked37.6893850
7Locked38.6824243
8Locked37.61204234
9Locked37.65572490
10Locked37.65692519
11Locked37.65602587
12Locked38.65642457
13Locked38.65632321
14Locked37.65922382
15Locked38.65602450
16Locked38.65922465
17Locked37.65892487
18Locked37.65042562
19Locked38.66182375
20Locked38.65662517
21Locked37.66072353
22Locked37.35842471
23Locked37.66042342
24Locked37.65772360
