Constant dropouts on 630mbps package
Jackorias
My internet has been nothing but shocking today. Fortunately, I'm not working, unfortunately, rubbish internet ruins a day off.
My speeds show as fine when using fast.com (unbiased, Netflix doesn't care whether you're Virgin, Sky, BT or whoever) but I'm getting constant slow downs. The VM status website shows no issues, and I've restarted my router setup. This happens on both WiFi and Ethernet on all my devices.
I've read that the VM Status page won't show 'localised' issues/faults, so wondering if it's anything to do with that?
2 REPLIES 2
Hero
Local Faults or Outage
Check for a known local fault on 0800 561 0061 - it is an automated service
This number often has details of an issue long before the web links.
Joseph_B
Hey @Jackorias,
Firstly welcome to the Community Forums and thanks for the post.
Sorry to hear that you have been having some internet issues. When your internet is running slow what are the speeds your hitting?
Have you tried following our troubleshooting guide on our website here?
Hope this helps, Joe
