Consistently slow broadband
For over a week now my broadband (East Midlands) has been consistently slow. My speedtests rarely go above 5 or 6mpbs down, and I doubt my connection is even reaching that with the actual download speeds I'm getting. I have the M200m fibre broadband package and use a wired connection.
Is this a capacity problem or is there something I can do other than change providers?
  • 15.68K
  • 1.64K
  • 2.67K
Re: Consistently slow broadband
You could try a factory pinhole reset on the Hub – a lot of the VM techies on here are suggesting it as a first option. Hold the pin in for 60 seconds.
Also, do a quick check that all of your coax connections are in nice and "finger" tight at the Hub and wall box and at any splitters/attenuators/etc with no “unterminated loose ends, and that the internal wiring is ok with no kinking or chaffing. Also check that all looks good with the outside cabling and wall box.
