Consistently inconsistent speed - Surbiton
We've been on Virgin media broadband for nearly 8 years and have consistently suffered broadband speed which has been all over the place. This has been particularly annoying in trying to listen to music (via Sonos), or watch anything through a streaming service (Prime etc). For example, I've run Speedtest 5 times today and the download speeds have been 9.46 / 214 / 0,78 / 7.76 / 1.11.
Please help!
From my router status: Downstream
12990000003.536256 qam21
21390000001.234256 qam1
31470000001.235256 qam2
41550000001.535256 qam3
51630000001.535256 qam4
61710000001.734256 qam5
71790000001.535256 qam6
8187000000235256 qam7
9195000000235256 qam8
102030000002.235256 qam9
11211000000235256 qam10
122190000002.235256 qam11
132270000002.536256 qam12
142350000002.536256 qam13
152430000002.736256 qam14
162510000002.736256 qam15
172590000002.736256 qam16
182670000003.236256 qam17
19275000000336256 qam18
202830000003.236256 qam19
212910000003.736256 qam20
223070000003.737256 qam22
23315000000436256 qam23
24323000000436256 qam24
Upstream
1462000004.4512064 qam11
2394000534.25512064 qam12
3537000124.55512064 qam10
4603000124.6512064 qam9
3ATDMA0000
4ATDMA0000
  • 15.68K
  • 1.64K
  • 2.68K
Re: Consistently inconsistent speed - Surbiton
Are you seeing the same problems on ethernet cable connected devices as on wifi connected ones?
If its been like this for 8 years what have VM done to try and resolve the issue?
You are also missing downstream data ( with the RS error count columns) and post up the recent network logs.
Meanwhile, check all your coax connections are in nice and "finger" tight at the Hub and wall box and at any splitters/attenuators/etc with no “unterminated loose ends, and that the internal wiring is ok with no kinking or chaffing. Also check that all looks good with the outside cabling and wall box.
The only ethernet connected devices we have are
1. Our mac which we rarely use. When we do, there are rarely problems.
2. A Sonos boost and
3. A MyCloud 1TB storage device.It struggles to talk to the Boost and vice versa on a regular basis.
VM upgraded our hub a couple of years back but it's not really helped
Here is the additional info you asked for:
1Locked36.6797300
2Locked35138265050
3Locked35133749320
4Locked34.9111756020
5Locked3571460320
6Locked3584420100
7Locked3547444320
8Locked35.550150527
9Locked35.533481611
10Locked35.522617390
11Locked35.525632910
12Locked35.712568410
13Locked36.313054650
14Locked36.38141550
15Locked36.36299060
16Locked36.64921770
17Locked36.33006710
18Locked36.62645630
19Locked36.32072000
20Locked36.61264720
21Locked36.61496630
22Locked37.3721460
23Locked36.6518810
24Locked36.6415100
I don't seem to be able to cut and past the network log without getting error messages from the forum - any ideas?
