martyp
  • 355
  • 30
Superfast
Message 1 of 8
Connectivity issues to some sites today
Hi all,
I've been experiencing issues today with my connection from around 10am. Ran the tests and showed all was fine, I did a speedtest at speedtest.net and got the right speed. I had a remote connection which kept dropping, a few other websites including GMail kept reporting there was no connection and downdetector wouldn't load the images on the page and wouldn't load correctly. The connection has been generally unreliable all day. I did a reboot of my Hub and router and it was ok for a little bit but then played up again so around 11:45 I took the power out of my Hub for about 3 minutes and although there have been some connection performance issues since I'm still having issues with Gmail and downdetector still won't load properly.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 8
Re: Connectivity issues to some sites today
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting the area. Be aware that it isn't a manned line.
Go round all the accessible co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some troubleshooting; to start with …
Can you set up a Broadband Quality Monitor (BQM) at thinkbroadband.com - this will give you an insight into what is happening with the signal at the other side of the Hub, it will take a few hours to get any kind of trend showing although you can post the link straight away.
 In the URL box paste the link you copied and then click OK - you can post the link straight away.
Then
Can you please
When the page appears DO NOT LOG IN but click ‘Check Router Status’.
Copy and paste the contents of the Downstream, Upstream and Network Log tabs onto here, if you get a yellow warning click the Post button again.
martyp
  • 355
  • 30
Superfast
Message 3 of 8
Hi Mike,
Many thanks for the indepth response. Details below, another annoyance that started today is many websites now asking me to confirm I'm not a robot and select images etc. for cloudflare etc. happening with hotukdeals, downdetector and also the thinkbroadband site. It's getting annoying having to keep selecting pictures of planes, cars etc.
I did check the service status page and it said there weren't any issues, I just called the status line and it said the same.
Checked all connections, nothing had changed there anyway.
https://www.thinkbroadband.com/broadband/monitoring/quality/share/d6cb1dc92cbff3d03cf9be958c48b395afe32650
1537000144.1512064 qam2
2325999934512064 qam5
3393999914.05512064 qam4
4462000194.05512064 qam3
3ATDMA0000
4ATDMA0000
1299000000238256 qam21
21390000006.938256 qam1
31470000006.538256 qam2
41550000006.438256 qam3
5163000000638256 qam4
61710000005.938256 qam5
71790000005.538256 qam6
81870000005.438256 qam7
91950000004.638256 qam8
102030000004.338256 qam9
112110000004.138256 qam10
122190000003.738256 qam11
132270000003.538256 qam12
142350000003.238256 qam13
152430000002.738256 qam14
162510000002.538256 qam15
172590000002.738256 qam16
182670000002.438256 qam17
192750000002.238256 qam18
20283000000238256 qam19
212910000002.238256 qam20
22307000000238256 qam22
233150000002.238256 qam23
24323000000238256 qam24
1Locked38.6140
2Locked38.670
3Locked38.6200
4Locked38.6150
5Locked38.6180
6Locked38.6220
7Locked38.6240
8Locked38.6180
9Locked38.9160
10Locked38.650
11Locked38.650
12Locked38.970
13Locked38.980
14Locked38.670
15Locked38.680
16Locked38.950
17Locked38.660
18Locked38.660
19Locked38.660
20Locked38.690
21Locked38.680
22Locked38.990
23Locked38.670
24Locked38.670
martyp
  • 355
  • 30
Superfast
Message 4 of 8
13/08/2020 09:02:37noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/08/2020 20:30:10ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/08/2020 14:48:8criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/08/2020 17:17:47criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/08/2020 17:17:45Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/08/2020 17:17:41Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/08/2020 17:17:36criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/08/2020 17:17:36Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/08/2020 17:43:46criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/08/2020 14:57:27criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/08/2020 14:57:27Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/08/2020 14:57:26Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/08/2020 14:57:21Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/08/2020 14:57:17Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/08/2020 14:57:17criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
martyp
  • 355
  • 30
Superfast
Message 5 of 8
I don't seem to get the cloud flare I am not a robot pages today (was getting them on all devices yesterday).
My google home mini is still saying it can't connect to the internet and on hotukdeals and down detector websites many images aren't loading. This is happening on my phone and on my laptop.
I've taken the power out of my hub for 10 minutes as well as my router and have also unplugged my google home mini and still keeps saying it can't connect to the internet?
My speed test results are as expected.
martyp
  • 355
  • 30
Superfast
Message 6 of 8
 this is an example of how I'm having problems with some websites still. The above two screenshots were on my phone. I tried two different browsers on my phone including one that I hadn't loaded hotukdeals on and both failed to load the images. I switched from my Virgin connection to my 4G and refreshed the page and all the images loaded fine which is the 2nd screenshot.
martyp
  • 355
  • 30
Superfast
Message 7 of 8
Downdetector website:
On my Virgin connection:
 switched wifi off and went to 4G then refreshed the page:
martyp
  • 355
  • 30
Superfast
Message 8 of 8
Just tried those sites again this morning and they seem ok again 🙂
Looks like something was fixed overnight.
