ladamus
  • 14
Connection off and on.
My broadband has been up and down all day. Ran diagnostics, it said something was wrong and they would fix it. Then I ran it  again, it said all good.
In reality the network connection is off and on. I can’t even connect to the router for more than two minutes, so I can’t even check log entries.
it is not just a WiFi issue, the computer connected via Ethernet has the same issue.
Is it the router dying? Help, please.
Any help is greatly appreciated
Adam
ladamus
  • 14
Re: Connection off and on.
Update: no connection at all. I cannot access the Hub at all and it does not react to resetting either .
Help please!
gary_dexter
  • 30.46K
  • 1.89K
  • 4.05K
What hub model do you have?
ladamus
  • 14
Hub 3.0
vmdg505/tg2492lg-vm
That’s all I can see on it.
gary_dexter
  • 30.46K
  • 1.89K
  • 4.05K
Have you tried a 60 second pinhole reset on the hub?
ladamus
  • 14
I have indeed. No luck, I am afraid.
