mforcevirus
  • 6
Connection keeps dropping while streaming
A few times today and some the other day my connection keeps dropping while streaming. When it comes back on I notice that my speed is 80Mb down when it should be around 350Mb. I've been on the phone to support in the past and resetting the router back to factory settings and restarting everything doesn't seem to fix it. Other people today have told me they have issues too but there is nothing on the service status that mentions any issues.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: Connection keeps dropping while streaming
Is that on Wi-Fi or ethernet connection ?
Anonymous
Not applicable
We should check the HUB stats to ensure they are in spec.
Could you access your router using http://192.168.0.1/ or http://192.168.100.1 for modem mode . You shouldn't need log in, select the 'Check Router Status' option and paste your 'Downstream', 'Upstream', and 'Network Log' tabs? Please copy/paste this data as text, split between multiple posts (Sometimes you have to click 'Post' twice due to an error message).
Could you please create a BQM (Broadband Quality Monitor) here, and post the live link?
